Question about Epson PhotoPC 3000Z Digital Camera
External Flash for 3000Z
I have an Epson PhotoPC 3000Z camera and am looking to purchase an external flash. I have been looking at a variety of external flashes and have a few questions. Epson recommends the Metz 32 Z-2 compact flash unit. The Metz compact flash units 32 MZ-3 and 32 Z-2 support the Special Camera Adaption (SCA) 3000 system. The Metz website states the following: The principal new feature of the SCA 3000 system is the ability to evaluate the digital data supplied by the camera's electronic control system. The ultra-compact SCA 3000 adapter transmits this information in a digital form to the flash unit. The SCA 3000 system has made it possible to implement the following functions, depending upon the type of flash unit used: - Digital transfer of film speed - Digital transfer of lens aperture - Automatic zoom reflector control - Integrated AF measuring beam - Second curtain synchronization - TTL flash exposure correction My questions are as follows: 1. Epson recommends the Metz 32 Z-2 compact flash unit. What digital data is actually exchanged between the Metz 32 Z-2 and the Epson PhotoPC 3000Z camera? 2. The Metz 32 MZ-3 is more complicated with a power zoom reflector and integrated AF measuring beam. Will this flash unit work to its fully capabilities with the EpsonPC 3000Z camera? What additional data, if any, is actually exchanged between the Metz 32 MZ-3 and the Epson PhotoPC 3000Z camera? 3. If the information sent between the Epson PhotoPC 3000Z and any flash unit (including Metz) is just a 'trigger to flash' message then ... Will the Epson PhotoPC 3000Z camera work with the Metz 32 Z-1 compact flash unit? Is there any benefit to upgrading to the Metz 32 Z-2 flash unit? or the Metz 32 MZ-3?
    Master:
  • 542 Answers
I have a Metz Mecablitz 50 MZ5 which incorporates an automatic exposure calculation unit which mounts on top of the camera. I normally use this unit successfully on a medium format and 35mm camera which are full manual. Even with the correct aperture, film speed, lens zoom settings inputted into the unit the exposure is wrong with the Epson. The firmware inside the camera doesn't work in a linear fashion as conventional film so reciprocal calculations cannot be conducted ie: 1/60 f8 = 1/120 f6. There are look-up tables inside the camera that calculate the exposure in an Epson Digital Camera kind of way. Epson UK are currently investigating the actual values used and how the camera calculates them so I can compensate when using the flash. My advice to you would be not to buy a sophisticated flash for this camera. No information is passed to the flash which acts as nothing but a slave to the camera. Even with a guide no of 50 in my flash unit the pictures are always underexposed and the correct exposure is difficult to work out without knowing how it works in the camera.
Posted on Sep 13, 2005
    Master:
  • 542 Answers
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
SOURCE:
Flash for 3100Z
I use a Sunpak 433D flash with my Epson 850Z camera. Do a search for vivitar in this forum and you should get a lot of hits.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Maximum flash sync
I have a 3000z, and have not noticed any problem with flash sync with even the fastest speed.
3000Z and Speedotron Flash power pack
You also may have a faulty hot shoe adapter or pc cord. Check them with an ohm meter, or with an old 35 mm camera. Or just short out the hot shoe contacts with a piece of metal and see if the strobes flash.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Can the internal flash be disabled when using externally attached flashes?
t is my understanding that you must use manual exposure (shutter and aperture) with an external flash. This shouldn't be a problem (set the camera to the settings on the guide chart that comes with your flash, and let the flash worry about the strength/flash duration necessary - provided it is an "auto" flash with a sensor)... I'm going to use a Vivitar 273 with my Epson 3000z... There are a few other threads on this forum regarding External Flash use.
External flash for the 3000Z
bought the Metz 32 Z-2 that was recommended by Epson. I did a great deal of searching/researching on the web, and eventually came to the conclusion (my personal conclusion...YMMV..as well as others) that it was worth the price. I've also had two (non-digitial) pros hold the metz name in very high regard. I like it so far although I haven't used it much for nice portraiture. I did use it at the beach one night in the *dark* from 10 meters (couldn't see *anything* on the LCD when snapping the picture) and a few turned out really nice. Some were not in complete focus, but hey, it was dark. I will say it is much larger than I expected. When mounted on the 850 it felt nice. But with the 3000 being a little smaller, it is rather large. With a teleconverter lens and the flash mounted together, the whole ensemble feels rather nice. I'd recommend finding one in person first. It does have about all the features one could want tho...
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Flash doesn't work
Make sure the flash is not set to the flash off setting. Check the batteries and make sure they are installed correctly. Recharge or replace the batteries if necessary. You can't use the flash in continuous shooting mode. Check to make sure your camera's flash setting is not set to use the optional external flash (see Appendix A).
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Why doesn't the Image Expert software recognize the camera?
If you have a version of Image Expert from a different camera, printer, or other product, make sure you install the version of Image Expert included on your PhotoPC 3000Z Software CD-ROM and use it when you are connecting to your camera. The correct version is named Image Expert - PhotoPC 3000Z (version 1.8.7).
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Epson PhotoPC 3000Z Digital Camera Logo
161 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
