Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi vs-50800 The tv will turn on and have volume but no picture. took back of tv board off just to look around to get familiar with tv. What can I do or how can i fix this. Petty handy person. Think you could help me thank you very much
  • lady_luck_70 Sep 17, 2008
    I have the same problem, no picture but lots of sound
    Genius:
  • 1,605 Answers
Take a look at the gun at theback of TV. if you don't see the beam. it is definitely the HV. I don't know it is worth fixing it. then, there may be something else is going too.
I did it once it is just not worth the time and money.
Posted on Oct 21, 2008
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
Mitsubishi VS50802 CRT rear projection
that is the capacitor.. that shouldnt be that expensive, so i guess they ripped you off.. in my country the repairment cost you less than 10$..
and yes, you need special tools and knowledge to fix this, so i would recommend you to go for some repairman before you can electrocute yourself trying to fix it, even if its unplugged...
Dec 26, 2007 | Mitsubishi VS-50800 50" Rear Projection...
I do not have a manual for my set
Howdy,
That Model is:
Height: 15 13/32
Width: 42 13/16
Depth: 22 19/32
Weight: 183 lbs.
I hope this information was helpful.
Good Day, Big Irish.
Nov 23, 2009 | Mitsubishi VS-50800 50" Rear Projection...
Can not power on the TV. When press the power bottom, the green light went and then went off in a few seconds.
I think tv is blown it should at leat make sound if projection bulb is broken it will cost alot to fix throught out buy new
Aug 01, 2009 | Mitsubishi VS-50800 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Red and green distortion
The convergence Ic needs to be replaced. I am not sure which STK number is used in that model as I dont have Info on the VZ6 chassis. But you can get a replacemeny IC with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jun 01, 2008 | Televison & Video
Mitsubishi VS-50800 on/off problem
It sounds like, and I'm only making an educated guess here, but I'm thinking your television is broken and you should probably get a new one if you want to continue watching television.
Oct 21, 2007 | Mitsubishi VS-50800 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
