Question about Roper RAX4232KQ Top Load Washer
Cold Water I have a roper washing maching that is about 6 years old. I can't wash in cold water.. It will wash in hot but not cold... Help me please..the model number is RAX4232KQ1 ( Top Loader) Joann
  • Anonymous Nov 14, 2008
    wont wash in cold water and stop at any cycle at rinse?
  • megan_orcutt Nov 30, 2008
    I have a roper RAX4232KQ1it will not wash in cold please help if you know a solution.
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 02, 2008
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
I just moved into a new place and hooked up my Roper 111-07 washing machine. I have notice that no matter what temperature I select for the rinse cycle, hot water is the only thing that comes out. I only...
Hello Stephanie Wells,
Since it is the "new place" that changed...
I would FIRST look to the COLD WATER supply
to make sure cold water INDEED comes out of the
MACHINE END of the hose.
Then move on to the cold water valve...
>> Take PICTURES before disassembly.
Not terribly expensive... Pretty easy to change.
(you may get your NEW PART as differently
connected than your old (PRESS FIT couplings
are replacing the OLD threaded type...
ALERT: PRESS collar in to release tubing)
HELPFUL VIDEOS:
Check these (USA) parts suppliers to
find your specific water valve
(even available through AMAZON)...
Let price/reputation be your guide...
ALL these folks peddle the same parts (opinion)
appliancepartspros
Search Over 2 1 Million Appliance Parts
AMAZON: Roper
285805 Roper Washer Washing Machine Inlet Water Valve Replacement
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Good luck
Carnac the Magnificent
May 08, 2017 | Roper Washing Machines
New roper wash. Mach. Will not fill on warm wash, but does on hot cycle
this could be a simple fix, where your hoses screw onto the back, ensure that there is a screened washer in place as your cold water is pushing the hot water back through the lines so the hot can't come through with the cold running as well, thats why it will only be hot or cold, scoot down to your white goods center and they will provide you with the correct washer screens for your unit, cost should be no more than about $3 a piece. good luck.
Oct 14, 2013 | Roper RAS8445KQ Top Load Washer
I have a 6 year old Frigidaire washing machine. It does not fill with water. All water lines have been checked and are okay. Washer goes immediately into the wash cycle without filling with water.
This is symptomatic of a malfunctioning water control valve- the hot water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else like the control board or connectors ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
I have a Roper washer which is about 15 years old and it has never run properly because the hot water trickles in so slowly that I can only wash with cold. Can you make a suggestion Thanks Roz
Make sure the hot water valve is turned on completely.
It is usually the cold water that creeps in because of clogged filter screens in the hoses.
Feb 21, 2009 | Amana NAV5800A Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Washing machine
HOT WATER VALVE IS FAULTY
Nov 29, 2006 | Indesit W 123 Front Load Washer
Roper RAX4232KQ Top Load Washer Logo
76 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
