Question about Innovage LCD Touch Panel Phone
Ring on the phone
I need assistance on why my phone does not ring when someone calls in and why it does not have a dial tone when using the handsfree
  • Anonymous Nov 14, 2008
    My phone is not ringing for incoming calls?
  • Innovage Master
  • 2,460 Answers
I'd be looking at power issues. Is this one of those deals with a wal wart? I see that batteries power the clock and LCD, but could the speakerphone and ringing functions be powered from an external power supply?
I see that someone is blowing these things out the door for under $20. Must have been a real big seller LOL
Carl
Posted on Sep 02, 2008
My vtech handsfree phone has no dial tone
then call your phone company and report outage. use someone's cell phone
Aug 10, 2017 | Vtech Lands Phones
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
Why can;t I hear anything on outgoing calls
Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST
Contact our team for assistance.
Mark
Motorola Support
Sep 14, 2014 | Motorola IT6-2 DECT 6.0 2-Handset Digital...
Does not ring
If you recently dialed 4-0 or 4-1, those are Do Not Disturb and Call Forward codes. if this is what happened, then dial the cancel code for both, which is 4-2. This is with internal dial tone, don't grab an outside to do this. You could have someone dial your extension to test if the ringer is faulty. if their call comes in as voice announce, have them add a 1 to their dial sequence and their call should switch to audible ring, and you will know it's not a ringer issue. Adding a 1 can be done continuously if you want to switch back and forth.
Jan 07, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Innovage LCD Touch Panel Phone Logo
114 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
