Question about Car Audio & Video
How can I unlock code on radio 1998 Honda? - Car Audio & Video
  • 1,586 Answers
Check your owner's manual to see if the radio code is in there. If not, bring title and registration to the dealer and they'll look it up based on the VIN of the car. They also will charge you anywhere up to an hour's labor to do this.
Posted on Sep 02, 2008
I need 1998 honda accord radio unlock code
Go to a Honda dealer's parts department.
They can get it using the VIN # on the vehicle.
They usually won't do it over the phone, but, you never can tell.
Some may want to charge you to remove the radio to get
the serial number off the radio. If they do, find another dealer.
Dec 14, 2010 | 1998 Honda Accord
I need the code t o reset the radio on my 1998 honda accord. The battery was disconnected for a while and noew the radio will not work without the code.
You will need to go to your local Honda Dealer. The unlock code can be obtained thru the Parts Department. You will need the VIN and proof of ownership (i.e. Title or proof of insurance). You will also need the codes that the radio gives you when you press and hold buttons 1 & 6. That will usually give you the codes, if not, then you will need to get the radio serial number. This can, usually, be found in the glove box. If not, then the radio will need to be pulled.
Sep 03, 2010 | 1998 Honda Accord
Get radio cde for honda accord
Press and hold numbers 1 & 6. This should give you some codes. Take these codes, the VIN and proof of ownership to your local dealership parts department. They can get the unlock code from Honda. If the radio will not give you codes, you will need the radio serial number. This can, usually, be found in the glove box, if not the radio will have to be pulled.
1998 Accord: 1998 Honda Accord radio code unable to get serial ...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} try https://radio-navicode.honda.com/
if the above suggestion is not successful ,then unfortunately the code will not be available for free (or cheap ) from anywhere on the Internet.
Main Dealer or a Decoding Service only
May 16, 2010 | 1998 Honda Accord
Radio reset
The code in the Glove box is just the serial number to the stereo, It is not the unlock code itself. Call a Honda dealer and give them this number. They should give you the code for free. They did for me.
cheers hope that helps
May 07, 2010 | 1998 Honda Accord
Unlock radip code,1998 honda accord 4 door
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
Jun 05, 2009 | 1998 Honda Accord
Unlock radio code
the radio station buttons numbered 1 2 3 4 5 6. enter the 5 digit radio code there. if it locks up or goes to error you must remove the negative (-) battery cable to reset the radio and try again. it will let you try 3 times.
Jan 01, 2009 | 2002 Honda Accord
Unlock Code For Honda Accord 98
you need to call the dealer to get the code. you might have to unhook the neg battery cable to reset the radio again if the code doesnt work. also somtimes the code is printed on a small white sticker somewhere in the car. around the glovebox or in a door jamb or in the trunk under the ash tray. just need to look all over.
Dec 21, 2008 | 1998 Honda Accord
Car stereo honda caccord 1998 code
Go to the honda dealer with the registration and some Id for a fee they will be able to unlock the radio or provide you with the code to do so. Note it must the original radio for that car. Good Luck
Dec 06, 2008 | 1998 Honda Accord
Radio unlock code
I need help fixing my radio on a 2006 Honda Accord...I could not find the code and after so many attempts my radio is saying ErrE and now i have found the code and now i can't start over with codes again....what can i do?
Aug 26, 2008 | 2006 Honda Accord
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
