Question about Refrigerators
Capillary tube replacement
My wife had a service technician come in to her store to repair a true TSSU-60-16 salad unit.He found a leak, repaired it & recharged it with 134A refrigerant.He also informed her the capillary tube was plugged & needs to be replaced.1. According to the website this unit is supposed to use 404A refrigerant, will the 134A harm it? 2. He said it will be $500.00 to replace the capillary tube, is this reasonable? 3. Will the compressor fail sooner due to the plugged capillary tube? It seams to be working O.K. since his repair.
  • 725 Answers
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Posted on Sep 02, 2008
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
Posted on Apr 25, 2017
A restricted cap tube will greatly reduce the life of the compressor.
I would guestimate that the job of replacing the cap tube will take about 3 to 4 hours, plus a new dryer / filter and refrigerant. ( about an hour just to evacuate the system). I am pretty sure your unit uses R134A. It should say on the compressor as well as the inside sticker. Cap tube restrictions are a problem with the R134 systems. Hardly ever had them with the old R12.
Posted on Feb 02, 2013
  • 112 Answers
The type and amount of refrigerant will be listed on the model number tag on the left side interior wall of the unit. A partial blockage of the cap tube must be cleared for the unit to cool properly and to allow enough cool refrigerant to return to the compressor to keep it cool. I have heard from a fellow technician recently who tells me that he has had great success cleaning rather than replacing cap tubes by adding Supco S8 oil additive to running units. I have not yet had the opportunity to try it but if it saves the trouble of removing and replacing the cap tube I am going to give it a shot.
Posted on Feb 03, 2010
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
Sep 19, 2016 | True TSSU-48-12 - 48 Sandwich Salad Prep...
Which is the measure of the capillary tube?? mi regfrigerator model is TFXW27F
Hello Roberto;
My name is Peter. I am a retired field service refrigeration technician.
Are you sure it is your capillary tube? If you found it broken, then you have lost your refrigerant. If you have found it broken, then you have a restriction in your seal system. In all of my years as a service technician I have never heard of a broken capillary tube.
A capillary tube is a short section of tubing 10-12" long. It is 1/16" in diameter with a sewing needle size hole through it. It is located coming off your evaporator coil in your freezer. On the one side of the capillary tube is 160 PSI of liquid refrigerant. The refrigerant passes through the capillary tube and transforms into 60 PSI of refrigerant vapor.
Don't give up. I am here to help you. Tell me more about what is happening, or better yet give me a call @ 443-306-1362.
Oct 28, 2014 | General Electric Refrigerators
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
My TSSU 60 16 is leaking water insie the cabinet. What should I do before calling exspencive repair guy?
Call me, I'm not expensive ;). Seriously, the drain tubes are clogged. Unplug unit and get a flexible piece of electrical wire. The drain tubes terminate near the compressor and usually drain in pan under there. The most common clogs are at the elbow and tee connectors. Good luck! :)
Sep 22, 2013 | True TSSU-60-16-DS-ST-ADA Refrigerator...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
I have a true fridge mod number t55u-27-8 we keep salad in it and it keeps freezing all the salad please can you help ritchie
Hi, there are 3 likely things causing the problem.
Thermostat contacts faulty
Capillary tube(the thin tube connected to the thermostat) broken somewhere
Capillary tube not making good surface contact with the evaporator/cold plate.
A Leakey door seal is normally indicated by excessive frost buildup on the evaporator/cold plate over a short period.maybe the thermostat knob is slipping and not adjusting the temperature level of the thermostat...........
May 16, 2011 | True Refrigerators
Model TSSU-48-08 Sandwich/salad prep table. I think it is a 1998 unit, so it has some age but is in nice shape, like new. I need to get it working. Doesn't cool. Compressor motor, evaporator fan...
You have it figured out...get it tested for leaks, fix them and recharge the unit...
Make sure to get a professional to do the work...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
Sep 26, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
TRUE Salad Unit freezing food/compressor will not cycle properly
Double check to see that you do have in fact, the correct thermostat. I have found a chart that shows that the differential is all over the board. There is a way to adjust these thermostats but is very time consuming and if you are not a refrigeration tech, you may struggle with the procedure.
Mar 25, 2017 | True 598-TSSU7218 SandwichSalad Food Prep...
Refrigerators Logo
2,058 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
