Question about Toshiba TDP-T3 Multimedia Projector
Flashing yellow light
My TDP-T3 turns on fine then after about 5 to 10 minutes automaticlly shuts off flashing a yellow light at me. It does this with or without the Bulb in it and the fan seems to be working fine. Help!!!!
  • BobtheBod Oct 14, 2008
    i sat on the phone for hours with person after person frrom the projector company and they kept telling me to send it in spend $138.00 for an assesment and you just saved me a bunch of money!! i love you wish i could hug you!
This problem is caused by the overheating sensor cutting in too early. Some bulbs seem to run hotter than others and the overhear sensor seems to gradually cut out at a lower temperature over time. The solution is simple. Open up the projector and you will find the sensor/cutoff bolted to the back of the lamp compartment (not visible from the lamp compartment), you need to take the top off to see it. The component is an Airpax 67L100. You can order a replacement from Digikey.com -- or other component vendors for between $5 and $9. Simply replace the current sensor with a new one (solder it in) and for just a few dollars you will be back in the game. If you want to give yourself a little more margin of heat replace the component with an airpax 67L110 (cut off at 110 degrees instead of 100 degrees). The extra 10 degrees will give you more ability to handle hotter bulbs.
If you want to verify that this really IS the problem before spending the $8 try unbolting the sensor and letting it remain loose. Since it is not bolted down it will not heat up as much and will likely solve the problem. Don't leave it that way though. Once you have satisfied yourself that sensor really is the problem order a replacement, solder it in, and bolt it back down so that it can do its job.
I hope that helps.
Posted on Oct 13, 2008
  • PaulHaverhil Oct 27, 2008
    On reviewing my earlier response I realized that I neglected to mention a couple of things so in the interest of completeness:
    1. I was assuming that you had up-to-date firmware in your projector. If you don't and you have replaced your lamp module you might be suffering from a problem that the latest firmware fixes. You can download a firmware update fromhttp://www.infocus.com/Support/Products/... (the LP530 is the same unit as the TDP-T3). Don't worry you can use the infocus firmware upgrade on your toshiba dtp-t3. The unit will announce itself as an infocus projector rather than a toshiba upon power up but otherwise you will notice no difference except for the changes introduced by the firmware upgrade.
    2. Another thing that I should have mentioned is that you should clean out the air filter screens on the lamp module. If these get blocked up with dusk and dirt it will prevent proper cooling of the lamp.
    If you have done these two things AND my original suggestion and you still have the problem it is almost certainly a defective lamp module. (Quite rare).
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
I have a toshiba TDP-S8 projector up until about a week ago it was fine but now when i try to turn it on either by remote or button on projector the yellow power light disappears then reappears about 5...
Check the color wheel if it is not turning when you hit the power button (light should flash) you have 1 or 2 loose caps on the bottom of the main board behind the audio input try to resolder them with low heat iron these are smt caps and very hard work on if you have not worked on this kind of job take it to a expert
good luck! ps make sure you glue them down
if you do get them to work to prevent a reocurance.
OR you have a power supply issue which
should be a swolen 3300 mf 10 volt cap
in the main power supply.
Aug 24, 2009 | Toshiba TDP-S8 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Toshiba tdp-s3 projector
still looking for a schematic, i'm a tech for 44 years myself, but on unfamiliar territory don't travel without the road map. The bulb probably isn't getting high voltage, but i'm unfamiliar with the circuitry. y'all showed having the schematic. but i couldn't operate your forum page
Dec 30, 2008 | Toshiba TDP-T3 Multimedia Projector
Toshiba TDP-T3 Multimedia Projector Logo
148 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
