Question about Epson PhotoPC 3000Z Digital Camera
Installing sheild or hood for 3000z
This is not my first digital camera, so I am familiar with the bright light problem with the LCD view screens. I bought the 3000z and can't see anything in the LCD when the sun is shining. I cannot set any controls or change any settings, modes, etc. I have had two sheild/hood aftermarket suppliers who, after seeing a picture I sent them of the back of the 3000z, said they could not make a product which would fit the plastic area where the LCD is located and still allow enough room to be able to use the control buttons..... I do not want to send this camera back, BUT, I can't use it without being able to set different modes, which requires use of the LCD viewscreen. So, after posting this problem, I've had several people suggest that I contact the same providers of shields/hoods - which, having seen a real clear example of the area, suggest they cannot make a sheild/hood for this camera. So PLEASE, if you personally have installed a sun sheild/hood on the Epson 3000z, Please explain how you did it.
    Master:
  • 542 Answers
I have been using Photosolve's xtend-a-view for about a year first on the 850Z and now on the 3000Z. It not only make the LCD visable in sunlight it magnifies the screen which is very good for telephoto and macro shot. I use it with the Eagle Eye with great results. Installing it on the 3000Z is easy. You carefully trim the velcro to 1/4 inch then apply the first strip across the top of the LCD very close to the screen. Then do the same for the sides. You will find the hood fits just right and leaves room the press the buttons on the right side of the screen.
Posted on Sep 13, 2005
    Master:
  • 542 Answers
They make an LCD cover compatible with the Epson 3000z. In addition, there is a lens on the hood which magnifies the LCD by 2.
Sunlight prevents me from seeing my monitor
If you mean the LCD display on the back of the camera you can adjust the brightness in the camera menu. Press the menu button, move to the yellow spanner with 2 dots top right, below this you'll see LCD brightness, highlight this and press set you'll then go to another screen showing a scale 1 to 7 use the left / right button to move the pointer closer to 7 to increase the screen brightness.
May 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
When there is a bright sun I cannot see anything in the digitail viewfinder; the camera has no optical viewfinder.Help!
1. Do you get the same problem in regular lighting as well? If you do, it could indicate an LCD chip level problem, and if your camera is under warranty, I recommend you get it replaced.
2. You could try using a "viewing hood" to block out the sunlight,as shown in the pic below:
You can purchase that online from HERE. I think it cost about $15-20
3.You could even try anti-reflective coating on the lens, although I do recommend the "hood" from point 2 above.
4. If you do not wish to spend $15-20 on the hood, you can try an inexpensive alternative. Take a piece of cardboard and cut it in such a way that one end fits exactly around the digital viewfinder and gradually tapering in to a narrower viewing area. About 2inches depth should be enough. Tape the edges, and voila! you have a hood. Should warn you that this may be a bit of an inconvenience as you will have to hold the hood in one hand and click with the other. But as long as it solves the issue...;)
Unfortunately, there is no other solution, as your camera does not have any other settings. Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 27, 2008 | Cameras
Backlight spoilt for dsc t90
When the display is to dark or to light, the manual says:
Adjust the brightness of the backlight (page 18).
On page 18 it says:
This sets the brightness of the LCD screen. When viewing images in bright outside light if [Brightness] is set to [Normal], reset to [Bright]. However, the battery power may decrease faster under such condition.
You also can press the button with the > logo, to change between view pictures and record.
Dec 08, 2013 | Sony CyberShot DSC-T90 Digital Camera
I solve the problem of extreme reflection in the lcd screen.
I assume you're talking about pictures taken outside on a sunny day. All cameras are hard to see in bright light.
Sep 13, 2009 | Kodak EASYSHARE M1063 Digital Camera
3000Z and Speedotron Flash power pack
You also may have a faulty hot shoe adapter or pc cord. Check them with an ohm meter, or with an old 35 mm camera. Or just short out the hot shoe contacts with a piece of metal and see if the strobes flash.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Stuck pixel on 3000z
Sounds like you have a dust spot on the CCD, you should send your camera in for cleaning.
Spot metering on the Epson 3000z
The spot meter area is small because I have photographed 2 people side by side many times, focused on ones chest then found that the "spot" had slipped into the little space between them, the bad focus not really showing up when I checked the LCD. (My eyes are old and so are my glasses.) Got home and found useless pictures. Sometimes I was outdoors in the sun and couldnt check the LCD. Some of the threads say the focus spot is "off center" with no acccurate way of finding it when using the viewfinder. I take some beautiful, wonderful pictures but these errors really tear me up. I've got to get the LCD box viewer with the 2x lens viewer I guess. All those years as a 35mm Canon F1 user I would long for a spot meter almost daily. Now I see that a matrix meter AND a spot is the real choice. I hope eventually to learn to outwit my 3000Z because it does give me such excellent pictures. Sometimes there is noise on a face, sometimes it is the focus and at functions it is so embarassing to ask a principal subject to wait because the *** or ***H procedures take so long. A wedding, other than the reception, would be near impossible in *** or higher. Good Luck, Dav.
LCD screen
I tried a hood from the HOODMAN and it was better than nothing but the best solution comes from http:\www.photosolve.com. They have a very reasonably priced metal hood that attaches with velcro. In addition it gives 2X magnification which is great for focusing macros, etc. I use mine with the Eagle Eye 5X lens and I get some really sharp shots because I can focus accurately. Try it. You'll like it.
Bad Pixel in LCD (not CCD)
My camera also has a one bad pixel in the LCD; my pixel is green. My camera was also ordered from Buy.com. They have been very helpful and my story is almost identical to yours for their return/replacement practice. It is really nice to see online companies that continue to offer 'great' prices and also provide great customer support.
Why doesn't the Image Expert software recognize the camera?
If you have a version of Image Expert from a different camera, printer, or other product, make sure you install the version of Image Expert included on your PhotoPC 3000Z Software CD-ROM and use it when you are connecting to your camera. The correct version is named Image Expert - PhotoPC 3000Z (version 1.8.7).
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Epson PhotoPC 3000Z Digital Camera Logo
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Thomas Stauber
Thomas Stauber
Are you an Epson Camera Expert? Answer questions, earn points and help others
