Question about Kenmore 63012 Electric Dryer
Kenmore blower wheel
Is there any other way besides removing the drum
  • john gagnon
    john gagnon May 11, 2010
    what make of dryer
  • 943 Answers
Hi is the blower broken that would be the only reason to replace the blower or is the dryer noisy if its noisy and not the blower the drum repair kit is available you get 2 drum rollers 1 idler pulley and a new belt the appliance doc
Posted on Sep 16, 2008
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Posted on Feb 18, 2009
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
Why is the dryer making a squilling sound
DRYER MAKES NOISES.
The blower:
The bearings:
Aug 18, 2014 | Kenmore Elite He5T Dryer Heating Element...
Kenmore he4t makes a whinning noise when it is not running
DRYER MAKES NOISES.
The blower:
The bearings:
May 16, 2014 | Kenmore Elite HE4 Electric Dryer
Drying humming but drum will not turn
the humming is from the motor,try turning the drum by hand,if you can turn the drum the motor is bad, it might start after you spin the drum but it will stop again,if you can't turn it the belt could be locked up on something or something is stuck in the blower wheel located underneath the lint filter,you might have to remove the duct that the lint filter slides into to get at whatever might be stuck in the wheel.
Feb 04, 2010 | Kenmore 63942 Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
My crosly dryer well not start
The fuse is mounted beside the heater element. You need to check for lint balls or a bad blower, very common on these dryers. use a butter knofe or a putty knife to pop the top. then get the screws that hold the front off and lift the front out the way. Inspect for lint and loose blower wheel. Remove the drum and vacuum out the dryer. Replace the fuse. Check out these repair pictures that show the limit beside the heater.
Jul 24, 2009 | Dryers
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Jan 03, 2007 | Kenmore 72602 Gas Dryer
Blower wheel on dryer is loose
Jclay, you are in for a little work here partner. On this model the blower is up-front. The dryer is going to have to come apart for you to tighten or replace the blower wheel. The end caps on the consol will pull off. Remove the two screws on each end securing the consol. Flip the consol up. There will be 3 quarter inch screws under the consol, in back, holding the top on. Remove these and the top will slide off, forward. Remove the bottom panel by the blower. Remove the lint filter. Remove the 4 screws attaching the front panel and door to the front of the dryer, remember to unplug the door switch cable. The drum now can be removed after removing the belt. Take the tension off the belt by moving the pulley over. Remember the belt configuration so you can put it back on right. Once the drum is removed you will now be able to get a wrench on the motor shaft itself so you can tighten or replace the wheel. Reverse the above steps and your back in business. Im going to attach a picture of a rear blower system and the way to take it off. Yours is up front but the removal will work the same way. Sometimes you have to cut the old blower wheel off because it's fused on with heat. Your part number for the wheel is 697772. Remember to unplug the dryer during this work..Catriver..post back.
Aug 30, 2006 | Kenmore 63012 Electric Dryer
Kenmore 63012 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
