Question about Cameras
Every time i try to turn on my carmera the screen says lens error what does it mean and what should i do about it?
It means your lens is broke mine does it every time i try and turn it on and i have to get a butterknife to open myt camera up to use it its a big hassle what you probly did was had it in a bag or something and the bag was dropped and the cammera lence face got jammed.
Posted on Sep 02, 2008
Carmera flashes fEE and will not function. We have tried on a D80 and a D90 with the same result. Seems as thought it will not focus on auto-focus or manual focus, same error code.
It sounds as if you are talking about a lens "tried it on a D80 and D90" which is a bit confusing because the Fee code I' run into relates to a memory card being full with no available space for more pictures files. If this is not the case then clean the cold contacts on both the camera and lens with a new, clean pencil eraser by gently polishing the contacts. be careful not to get dirt into the camera body. The contacts look clean but for some reason over time thy get an oil residue on them and cause a host of ignorant problems including no focus or focus confirmation.
Apr 18, 2011 | Cameras
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
My digital camera has a lens error
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
Whe I turn the carmera on it says lens error and then the whole camera shuts off, I am not sure what to do . Is it broken?
Jul 02, 2010 | Kodak EasyShare C713 Digital Camera
I cannot turn my camera on.
If The Lens Is All The Way Out And Wont Go Bak In Thats Why The Camera Wont Turn On Not The Other Way Around. Try Very Gently Turning The Lens And Turning The Camera On At The Same Time Till U Hear A Click That Should Do The Trick.
Feb 09, 2010 | Samsung SL420 Digital Camera
WHAT DOES IT MEAN WHEN THE SCREEN IS BLACK AND SAYS E18 AND MAKES A VERY STRANGE NOISE AND i CAN'T TAKE A PICTURE.USUALLY IF I TURN IT ON AND OFF SEVERAL TIMES THIS WILL GO AWAY
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 29, 2009 | Canon PowerShot A95 Digital Camera
Carmera not opperating
lens alignment or onboard memory problem , try using a memory stick instead of onboard memory ,and LIGHTLY TAP THE LENSE if you can get it out. if that doesnt work i suggest to go to a sony repair center
Sep 27, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
CD error
Usually the turning longer than usual means the laser is having a hard time reading the disc. See if the same disc will work in another cd player, if its not the disc try cleaning the lens with a lens cleaning disc. ER (error) usually means a> the disc is unreadable or b> the laser is dirty or inoperable
May 26, 2007 | JVC RC-BX33 Cassette/CD Boombox
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
