Question about Refrigerators
GE Icemaker PFSS6PKXASS
Our GE refrigerator is les sthan a month old and our icemaker stopped making ice. The icon above the "Reset Filter" is lit, but I've removed the filter and replaced, plus tried to reset it with no luck -- the icon stays lit. And unfortunately the GE manual is of absolutely NO help as it doesn't even tell you how to reset the filter. Suggestions? We are nearing our 30 day return date for this product from Sears and I'm seriously considering taking it back.
  • bsabal Apr 16, 2009
    Just wondering...I can't get the "reset filter" light to go off even after holding the button down 3-5 sec.  The little sound does happen as if the unit has responded, but the light stays on. This has been since the frig was installed a couple of months ago, so it isn't a dirty filter.  Wondering what else I can do.  Thoughts?
  • thebear8me May 24, 2009
    I just recently purchased the GE PFSS6PKXASS and the reset filter light is on and will not reset. any ideas? I have tried holding the reset button down until it beeps but it still will not go out. the manual is useless. thanks
  • 74 Answers
To reset the filter light you need to hold the button in for 3-5 seconds , the light will usually flash while you hold the button down then it will go solid and then go out once you release the button. The ice maker will only make ice when the freezer is cold enough approx -14c . Did it make ice ok before ? There is the possibility that when changing the water filter air got into the system and has not bleed out of the ice maker feed tube yet.
The Ice maker can usually be put into a test mode by turning it off , wait 30 secs then turn it back on and press the ice level sensing paddle back three times within 15 secs of switching the ice maker back on . The ice maker should then go through a forced harvest cycle and ask for water at the end of it.
Hope this helps
Posted on Sep 02, 2008
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and now will not work automatically. It will work...
    Good day!!!!
    This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
    Hope this information will be helpful..
    Thanks for using fixya...
    Aug 29, 2011 | GE Refrigerators
    Refrigerator has stopped making ice and the light is blinking above the ice maker switch. what do i need to do to correct this problem?
    My book says that ice cubes may be stuck in the ince maker.
    Turn off the icemaker, remove the cubes and turn the icemaker gake on.
    Feb 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
    Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
    Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    New ge fridge ice maker stopped producing ice
    check filter or waler valve may be is the icemaker call service
    Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    Whirlpool refrigerator stopped making ice.
    If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
    1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
    2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
    If you got this far and need more info to DIY - ronbuice.com
    Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
    GE Refrigerator Stoped making ice
    the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
    Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker isn't making any ice
    Your fill tube that fills the Icemaker could be froze up, The plastic tube that goes into the icemaker. Sometimes they get froze shut. You can remove it from the back of the fridge, just pull it out from the back and take a look. If that doesn't work, Let me know.
    Bill
    Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    I have a GE side by side refrigerator its about 7-8 yrs old it has ice and water in the door I replaced the water vavle last month but now it has stopped making ice but still dispenses water what might the...
    If it's not the water valve, it's the icemaker. Since you have just replaced the water valve and it's not calling for water, I would say that the icemaker should be replaced.
    Apr 04, 2008 | Refrigerators
    Open Questions:
    Refrigerators Logo
    1,937 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
