Fujitsu AMILO PC Laptops Logo
Posted on Aug 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced option menu with the following options. safe mode safe mode with networking safe mode with command prompt enable boot logging enable VGA mode last known good configuration directory service restore mode debugging mode disable automatic restart on system failure start windows normally reboot return to os choicesmenu. Can anybody provide awalk through that will help me restore factory settings please
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 214 Answers
  • Posted on Aug 03, 2011
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
214
Questions
Helped
63501
Points
450
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Repair manual for fujitsu amilo pi 3560 pc laptop
Computer repair manuals are not available for several reasons, including that components may change and that manufacturers do not want the liability involved in unskilled people working with electronics. As it is several years old it is out of warranty, so first Google amilo pi 3560 technical specifications to discover what you can about exact components. Then Google the repair procedure you wish to perform, along with the make/model, for example replace hard drive amilo pi 3560.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
How do i restore my fujitsu siemens amilo laptop to factory settings without the cd
hi,
if your laptop has the manufacturer installed recovery partition.in system restore sellect this.you will get a warning saying that all data will be deleted.press ok. restart.windows will be as was on the day you got it.
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
Want to factory reset
When you say "want to factory reset" do you mean you want to factory restore/recovery your OS? If so Does you laptop have a recovery partition? Do you have a Factory Recovery Disk? Could you be more specific.
I have a fujitsu pi 1505, when i switch on the laptop starts up but goes straight to a black screen with a flashing line _ . could anyone shed some light, thanks
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
1helpful
Hello, I have an Amilo pi 1536 and suddenly all my network adapters stopped working. Windows displays error 31 in all of them.
Use an another laptop /pc and download the appropriate drivers from the fujitsu siemens website and then re-install them. possibly corrupt files at the registry?.....
let me know how you get on!
Password when I start up my Fujitsu Siemens Amilo Pi 1536
hi astrid
can u please explain is the password on bios
Factory settings
cd come with a laptop it has been a recovery cd or something like that u have put it your laptop start setup your pc has been stroed as compay defolt setting
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
