Question about Canon imageRUNNER C3220 Color Copier
Canon IR C3220 cannot print multiple pages..ONLY able to print one page
Hi all,
my office has canon IR C3220.however i only can print one page even if i set to 2 copies.
pls assist!!!
  • 1 more comment
  • ahtshun23 Sep 19, 2008
    i have reinstalled the printer driver. I'm using Canon CLC iR C3220-C2 PCL5c driver....is this a correct driver?
    i also tried to download th same driver from canon sites,installed but issue not resolve..
    pls assist
  • Piggy Angel Dec 16, 2008
    Hi everyone,
    I have a Canon IR C3220 copier in my office. It always printed 1 copy instead of the number of copies (e.g.) that I have specified for print job.
    For example, I have specified to print 2 copies but only one copy was printed. This happened for all document type.
    I have reinstalled my printer as well as upgrade to the latest driver provided by Canon on their website but the issue is still not resolve.
    Please assist.
  • galexandr Jan 12, 2009
    hey guys, i have a PRINTER ISSUE, i have a Canon C3220 and i dont know what is the right driver, please help.
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1  or  -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
Posted on Jan 16, 2009
I had same problem with my Canon pixma ip4600 and 4300, it works fine on one of my laptop that has XP but will only print one copy at a time on my laptop with Vista. After a long time playing around with it I found if i set the printer setting range to print pages 1 to 1 ( or 1 to "number of pages in doc"), then put in how many copys you want and click collate.
It worked for me so hope this helps :)
Posted on Oct 11, 2009
If i give only 1 page for print it takes multiple pages
Posted on Oct 28, 2009
I have had this printer for years and works perfectly fine. Check whether the drivers PS/PCL are installed correctly or reinstall them.
Posted on Sep 18, 2008
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
Will only print page 1 of multiple pages and only displays "page 1 of 1" even though there are multiple pages to the doc.
try to do the printing with another komputer? is it solved?
check the OS and office is it working properly? (infected by virus or driver corrupt, etc) if the OS healthy:
try to reinstall the printer driver...
(if the problems still exit, well try to check the hardware, if you don't have that skill, better bring it to the expert :) peace..
Feb 06, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
My office has a Canon color imagerunner C3220. I want to use it to enlarge some images for a seasonal decorating contest. How do I break an image into pieces so that I can enlarge it into multiple 11x17...
I can help. In order to do this, you press the "copy ratio" then you select "multi page enlarge" from there, you can either select the number of pages you want to use (meaning the machine will calculate the percentage by which it enlarges) or you can select the ratio you want to use ie how big you want it to be (the machine will calculate the amount of pages to fit that ratio)
I hope this helps.
Dec 05, 2008 | Canon imageRUNNER C3200 Copier
How to print and staple landscape using Canon 3220
HI
You go to you printer properties(you will find it if you right click on the printer driver under printers and faxes in the controll panel),select printing prefrences,page setup,there is a option for landscape printing.Next to page setup is the finnisher settings,select the stapler option.
Nov 11, 2008 | Canon imageRUNNER C3220 Color Copier
Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Aug 01, 2008 | Canon Color C3220 Copier - Color...
Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Nov 09, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3220 Color Copier Logo
1,721 people viewed this question
old marine
old marine
