Question about Karcher 2500 PSI Pressure Washer
When squeeze trigger to start spraying my pressure washer stops running
When i start to spray and squeeze the trigger pressure washer stops running
  • Anonymous Apr 05, 2009
    my pressure washer is not creating pressure????
jmgldsmth
  • 1906 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
  • 174 Answers
SOURCE: I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Posted on Aug 18, 2009
  • 251 Answers
SOURCE: We have a Karcher G2500VH pressure washer. If you
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Posted on Mar 08, 2010
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
My electric GPW 1600 doesn't stop running when I let off the trigger?
Mostly they don't.
In order to ensure there is no delay in building up pressure for the next spray requirement and to lighten and cheapen the design, the motor is kept running to keep maximum pressure in the line and surplus pressure is recirculated through the pump after being ejected through the unloader or regulator valve.
Jul 16, 2016 | Electric Garden
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Why does my pressure surge
Common problem across brands. When you spray water the drop in pressure triggers the motor to take the hose pressure ~ 30 psi and boost it to ~ 3000 psi. Water coats these parts with calcium (hard water) or other junk and water contains bacteria which causes slime and scale. Once that pressure switch / valve is sufficiently clogged it doesn't move smoothly so it can fluctuate between sending a yes / no signal about whether you are squeezing the trigger or not. This causes the pulsing.
EZ test: take the the tip off the wand, start the unit, squeeze trigger - should run continously with no problem. If it does for sure you need to watch a video on dissembling and cleaning the valve body. It is not hard but you must work carefully to avoid losing parts especially springs and take digital pictures to record the order for reassembly.
Jun 04, 2014 | Dewalt DPD3100 Gas Pressure Washer
When the washer is not spraying, the motor cycles on and off. Eventually the motor overheats and shuts down.
You shouldn't let the washer run for more then 30 seconds without spraying. If you let the motor run without squeezing the trigger, the pump will overheat and damage the motor. You may also need to change the spark plug and clean/replace the air filter.
Jun 06, 2011 | Karcher Garden
Washer has low pressure. but can see pressure build up in hose. then when squeez triger motor stops.
Hello, W/D here.
Sounds like it may be air locked. Connect the hose to the washer. Connect the wand and hose to the washer. Open the supply water, and hold down the trigger on the spray wand. Be patient, this can take several minutes.
Now crank the washer.
Best regards, --W/D--
Feb 01, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Engine runs great, when i turn the hose on it dies.if i hold the trigger and start engine it runs, as soon as i release trigger the engine dies
Make sure thre is no air lock in the system line. So first of all use a clean line to wash off and blow out any dirt in the spray gun.
make sure the engine is having good fuel and power it on to run and warm up . let it run over without any load on it . Now turn the hose on it and power it on slowing, do not stop but keep it running to power spray . The accumulated dirt might come off and make the run smooth after some time.
Sep 18, 2010 | Karcher 2500 PSI Pressure Washer
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher 2500 PSI Pressure Washer Logo
394 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
