Question about Toshiba Satellite L25-S119 Notebook
Cannot access volume control
1.
the volume control icon does not appear in the task bar.
when the computer is started the following warning appears: "CANNOT ACCESS VOLUME CONTROL"
3 The sound from cd and downloaded music can be heard perfectly but the sound from downloaded videos like youtube dont get any sound.
Please help me. Thanks in advance
  • claude ranupas Sep 02, 2008
    Thanks for the hint I'll try that. Let you know the results.
    cranupas
  • Anonymous Sep 27, 2008
    cannot access volume control
  • 66 Answers
Just try repair windows or scan ur drive in antivirus maybe virus disable that volume
Posted on Sep 02, 2008
How to get a windows vista task bar zoom icon to appear
Go to Window's task bar, go to start> control panel > accessibility. under the visual assistance panel, click next to the box that mentions showing the icon in task bar does it work?.
May 28, 2014 | HP Pavilion dv6000z Notebook
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
How do I reapply the volume icon to my task bar?
i hope that you are using windows 7 operating system...
if so , to reapply the volume icon to the task bar go to control panel, then click Notification area icons then the icons and their behaviours will appear.. Under the behaviours click the drop down list box of the volume icon and choose show icon and notification then click ok . that's all now you will see the volume icon in your task bar ...
have a nice day !!!!!!!!!!
Aug 31, 2011 | Microsoft Windows XP Professional
How to hook-up speakers to xp7
Here is the solution for you.Please follow the below steps and fix your problem.
1 . Click on the "Start" globe or button and then the "Control Panel" label. The Control Panel main screen will display on your monitor. Click on the "Hardware and Sound" link.
2 . Click the "Manage Audio Devices" link in the "Sound" section on the Control Panel screen. The "Sound" configuration window will then open.
3 . Click the "Speakers" label under the "Playback" tab. Click the "Configure" button to open the "Speaker Setup" configuration window and select the "Stereo" option. Click the "Next" button.
4 . Enable the "Front Left and Right" option box by clicking the check box. Once the check mark appears in the box, click both small speaker icons to test the sound from the speakers. You should hear sound from the two right speakers when you click the speaker icon labeled "R," and the two speakers on the left should produce sound when you click the icon labeled "L."
5 . Click the "Next" button and then the "Finish" button to complete the speaker setup.
6 . Adjust the volume by clicking on the speaker icon near the time and date area in the task bar. Use the slider control to adjust the volume to the desired level.
Thanks.
Dec 24, 2010 | Dell A215 Computer Speakers
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
I can't hear the sound from my computer
Follow this steps bro, and I've attached some image so that you can easily configure your problem.Note! this steps is for windows XP Operating System use. 1.Single click volume control icon at your task bar. 9c3a774.jpg
Aug 17, 2010 | ASUS Computers & Internet
My microphone is showing that it pics up sound but when i record somthing from the web cam theres no sound playing back?
1. check the volume control ( master volume) on the pc found in the task bar of the Windows OS (operating system) at the bottom right usually. The speaker icon.
2. double click and your master control will appear. check to see if the master is "muted" or at setting.
Mar 11, 2010 | Sabrent SBT-WCCK Webcam
Start Task bar not showing
Press the Windows key to open the Start menu, then right-click the start button and choose properties.
Next, go to the task bar tab and
1. Uncheck auto-hide
2. Check keep task bar on top of other windows
Dec 11, 2008 | Computers & Internet
My taskbar does not appear when I am viewing web pages
It sounds like you have your task bar set to auto hide. I'm not too familiar with this brand of laptop but if you are using windows you should be able to follow these instructions to fix this. If you know how to get to the control panel (start menu) and click on appearance and themes there should be a task bar and start menu icon there. Click on that icon and select how you want your task bar to be displayed.
Nov 10, 2008 | Acer Aspire 5100 Notebook
Warning "cannot access volume control"
are they raw files from youtube or have you converted them to avi's ?
Files downloaded from those sites usually end with .flv i believe it is.
Robert
Aug 30, 2008 | Microsoft Windows XP Home Edition
Toshiba Satellite L25-S119 Notebook Logo
276 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
