its low on refrigerant,this is normal after about 2-3 years use,it costs about $50-$125 to evacuate old refrigerant and seal and recharge system with new proper amount of refrigerant being it R134a or R22 freon
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
It can be recharged but you would first have to locate and fix the leak and then refill. Then add a schraeder valve and refill at the port till suction line is cold to touch and starts to sweat. That's it!
somewhere there is a "knockout" or "plug" or something similar you have to remove or replace it to get it to drain through the hose, there should be some documentation in the owners manual about it, try troubleshooting in the back of the manual. If not look directly into the hose outlet and see if theres a plastic plug there, if there is use a screwdriver or something similar to GENTLY remove the plug, you may have to just study the machine when its running to get a better idea of how the water drains, maybe the machine came with something like it in one of the plastic bags the accessories came in.
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
