Panasonic Microwave Model # NN-SD986S is not working. When you try to turn it on, it will run for 2 seconds without spinning, and then the unit will shut off.
What can be the cause? Is this repairable?
The glass tray keeps rotating even when the door is open. The When you try to turn it on, it will run for 2 seconds without spinning, and then the unit will shut off. Can this be repaired? how much would it cost? What is the cause?The glass tray keeps rotating even when the door is open. The When you try to turn it on, it will run for 2 seconds without spinning, and then the unit will shut off. Can this be repaired? how much would it cost? What is the cause?
Put
in time, push start and unit runs
for 2 seconds, relay clicks, unit goes off. Cook time on display goes
off and clock time comes back. Bad upper interlock switch and charred
connector
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
That may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron.
I do not recommend that a person without training and experience ever work on these models.
You should be able to locate a Panasonic-authorized servicer here:
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1
I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop.
I have the exact same problem.....any hope?
