Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Monitor does not work!!
My Problem is one day i went to turn my monitor on and the light went from orange to green... but it said no signal, and went totally black, and left the little light green. i tested on several computers to see if it was my graphix card. it isnt. so i did a "no no" and took the monitor apart. i discovered the problem, and it is on the power cicuit board where the power form the wall comes in to the monitor. one of the itty ***** black chips. there are 5 small ones, and on large one. the on all the way to the left, and to the top of it has been melted and looks like there was too much power to it. it "bubbled" the plastic, blacked the motherboard some, and also blackened the solder holding it in place.
my question is, where can i get just this circuit board.. and how much would it cost??
thanks for the help in advanced
  • lj_racer36 Sep 02, 2008
    oh and i forgot.. i also noticed a change in contrast and brightness in my monitor. it was pretty dark ( set 50 50) and then the next day it was very very bright, to the point where when i would open a white page it would actually hurt my eyes. and it was like this for the next few days, settings were still 50 50 for brightness and contrast. then it didnt work after a few days.
  • 4 Answers
I had identical problem with my. I fix it by purchasing new chips from China (minimum 250pcs)
I have plenty on stock. If you like, I can fix it for you, or send you parts and you can fix it
Posted on Nov 15, 2008
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Turned it on a minute later went black
Good day sir/ma'am hi, if you monitor turns black, here are the more common probable reasons;
  1. Your PC went to standby the screen saver kicks in, just reset your PC then the monitor will power on again.
  2. If not, your PC is not giving you video signal, check to see if another monitor will work, we then know what part is bad, the monitor or the PC.
  3. If the monitor is the culprit, then your monitor's back light or inverter board just went bad. you need to replace it.
There are usually two main circuit board on your monitor, the power supply board and the main board, at this point, you need a professional to do the work.
The process is opening the monitor and locate the LCD screen connection to the main board, to check if the contact is snug. we then test. if still nothing happens, Then we go to the power supply board, to check for connection problem, It would help if there are light signs, like blinking, orange, red, green and the likes? Anyway, if the power supply board is not the faulty one, we substitute the main board with a good one and test to see if it will work, test again. If still no respond, we test a new LCD unit, then test, at this point the monitor is working already, if not, we then replace the power supply board. Huh, very expensive, we already have a new monitor. Reminders, these are to be done by a trained personnel. If you attempt to service this, its expensive, so I suggest you let the service shop do this for you to replace only the faulty part.
Nov 21, 2009 | Westinghouse L1975NW Monitor
My monitor went black this morning so i rebooted my system. didn't work. i then turned it off and it will not turn back on.any ideas
check screen light is it light green/yellow or is it orange in colour.....if it is orange check PC is turned light green also....if not then it defined that their is a problem with your PC itself and not the screen......have a technician looked @ your PC.....
Nov 05, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Green light flashing, but monitor won't come on
Sounds like signal issue, some older monitor lights do not turn orange when no signal is present from the computer. They simply blink instead of staying solid.
- I would test to see if monitor works on another computer with a known working monitor. If the monitor works then you know you have a video output issue.
If the monitor does not, you have a dead monitor.
Cheers,
Oct 21, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Sylvania L17 monitor for computer not working
Emily, First thing I would check is to make sure your computer is putting out a video signal by plugging it into another monitor. If the second monitor works then there is probably an issue with the video controller in the monitor and will require a repair by a qualified tech.
Good Luck
Ken
Aug 17, 2008 | Sylvania Computers & Internet
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
95 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
