Pentax Optio S Digital Camera Logo
Anonymous Posted on Sep 13, 2005
Freeze Up My Pentax Optio S, froze on me today with the lens out, and after a while I wable to reset it but the screen wouldnt come on. Finally I got a message on the screen that says "A90" Anyone with this issue? Thanx in advance.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Feb 28, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
21556
Points
36
A- I have a Pentax Opio S hence I had to get the "fwdc110p.bin" file here:
http://www.badongo.com/file/707791
B- Drop this file on your SD Card at the root directory (same level as DCIM folder) or as described by the following link and then close your camera to OFF:
Attention: Do not load this file yet onto the camera i.e. the menu+power on procedure, follow step C first...
Important!!! Insert a fully charged battery or connect to an external power source.
C- Open the now infamous "Secret Menu" in order to re-initialize your camera prior to re-installing the new firm ware: Simultaneously press MENU + Flash symbol button + Power ON...a white screen with data written in black should show.
Then a sequence of buttons must be pressed: 2 times the focus button (flower, mountain, MF symbols button) followed by 2 toggles to the Right of the "OK" button...then press MENU once and voile...the Secret Menu appears!
Using the down toggle of the OK button, go to ROM UPDATE then go down to "SYSTEM INITIAL" and press OK. Press another OK to re-initialize your camera.
Once this has been completed, turn your camera off.
D- Load the firm ware by opening your camera with the MENU+Power ON procedure...finally this should be posting "Complete" after the "Loading" message, instead of the "Error!" that we initially kept on having.
Your camera should be working perfectly! Only thing is that you will have to redo your personal settings on it from scratch...but hey, this is much better than to wait for months to get your camera back from Pentax and save that money for your next photogenic trip!
Anonymous
Level 2:
Novelist:
  • Expert 196 Answers
  • Posted on Feb 15, 2006
Anonymous
Expert
Level 2:
Novelist:
Answers
196
Questions
Helped
106813
Points
441
The A90 error code means you have to update your firmware. You do that by charging the battery to the max, and follow the steps of reburning the new copy of the firmware (Power + Menu button). You should load the fwdc110p.bin file. This should solve the problem.
Lens stuck on pentax optio m40,
remove lens and reset carefully. it will be okay
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Lens wont go back in once camera is turned off.
lens motor probably blew a SMT fuse when it got jammed. either take it apart and probe for an open fuse with a miltimeter and jump it with a blob of solder, or remove batteries for 48 hours and try again. Maybe a hard reset (no battery for 48 hours) can reset a shunt type protection.
Optio M20 Stuck on Zoom in and out!
you have a timing problem,the gears for your housing is out of calibration with your focus lens inside of the housing. you must take the camera apart to correct the problem.there is a flywheel type of ajustment in the top of the camera that can be turned to bring the camera back to its reset position. it is bad to keep turning on the camera as this may danage the gear that is out of time.
Optio s6 frozen
By recharging the battery, and then restart the camera, it may just work.
Because you were working on a movie in the camera at the time it quit, that file may be corrupted.
It would be interesting to see what has happened on this problem.
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
1helpful
Pentax optio m20 .. on-off immdly
Can't get it to stay on!
try to take out batteries and put them back if it doesnt work right away with change of memory card.
1helpful
2answers
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
