Question about Frigidaire Washing Machines
Frigidaire FWX233RES4 top loading washing machine won't run rinse cycle
HELP!! lol My Frigidaire FWX233RES4 top loading washing machine won't run the rinse cycle. It runs the wash cycle fine, and if I turn past rinse, it will run the final spin, but it won't rinse. :(
We replaced the belt on it about 3-4 weeks ago, and I can't help but wonder if something went wrong. It's worked fine since then... up until now.
Any help would be greatly appreciated!
  • Mysterious1 May 11, 2010
    Well, it turns out someone had "inadvertantly" shut the cold water faucet off. Simply turning the faucet back on solved the problem in a jiffy. BOY, do I feel silly!
5 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
Posted on Dec 29, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire FWX233RES4 washing machine won't work
the humming noise is problably the drain pump, which problably has something (sock or such) blocking it, by removingthe fornt panel youlll be able to acess t hdrain pump assy, to check for a blocklage,,( UNPLUG UNIT LIVE WIRES!!!)
Posted on Jan 30, 2009
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire top load washer does not spin until I depress the lid lock switch
Is the strike still in place on the lid? What is the model number?
Nov 20, 2013 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Wash Machine
It may be it the Lid switch... bad lids swithes will stop washers from going into the spin and pump out cycle...
Sep 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
432 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
