Question about GE 25932 Cordless Phone
Do Not Disturb is on phone does not ring
I do not know how it happened, just suddenly "do not disturb" is lit on phone, I do not have a button on either base for this and nothing on the menu. There is nothing in the manual.
GE Model 25932 Series phone, 5.8GHz cordless
  • 1 more comment
  • Anonymous Oct 05, 2008
    phone won't ring and I can't call out. It just says "do not disturb" in window. When i call my phone from cell phone it goes straight to voice mail.
  • crystal4 Dec 22, 2008
    I've had the same problem with the do not disturb button. I've pushed the button doesn't help. We unplugged the phone for more than 30 hrs still hasn't cleared the problem. Any info would be helpful? Thanks!
  • bl1964 May 11, 2010
    do not disturb
I had this happen. After searching around here and elsewhere, I decided to look at the base station for the phone instead of the phone itself. In the lower right corner of the base station is a button labeled "Do Not Disturb" in inset print. The red LED above it was lit. I pressed the button and this cleared the problem.
Posted on Oct 15, 2008
Amazing how simple this was thanks
brett fairbanks alaska
Posted on Nov 08, 2008
Thanks, Rubin. I do not have this button. I did however unplug everything for about 28 hours and replugged the phones in. The problem is gone.
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
How do i take off the do not disturb from my avaya 12 button phon
There should be a button your phone that is lit green. Press it.
OR, you can try to hit "FEATURE 01"
Dec 02, 2008 | Avaya MLS 12 Button Non Display Phone...
PHONE WILL NOT RING
on the phone i used to own i would have to press and hold the do not disturb button and it would beep telling me that that feature was turned off.....try it and let me know
Sep 28, 2008 | Uniden Cordless Phone
GE Cordless phone "Do not Disturb" setting
There is a button on the main base that says " Do not disturb" my 4 year old son must have pushed it. It was an easy solution.
Thank you!
Jun 16, 2008 | Uniden Cordless Phone
Uniden corless phone says Do not disturb on screen
Press # when handset is not in use and hold for several seconds. Repeat on any other handset experiencing problem. Do not disturb will be off and phone will ring.
Jan 08, 2008 | Uniden Cordless Phone
No incoming ring
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Dec 23, 2007 | GE 28111EE2 Cordless Phone
When someone calls the buttons flash but doesn't ring.
Your ringer has been switched off..to solve this press the menu button(mute in most of the sets)and press it until you see the option ringer press + to change it to off and then press menu again until you see the main screen...Thats all..
Let me know if it worked..
Oct 20, 2007 | GE 28111 Cordless Phone
I don't know how to turn off the Do Not Disturb
According to the instructions, you only need to press the "do not disturb" button again.  The button is on the base (not the phone).
Sep 30, 2007 | GE 21028GE3 Cordless Phone
Do not disturb
When Lit it shuts off the ringers to all phones register with it (the headset that came with it up to 4 sets) and when not lit they ring. If you have another phone other than the 3 cradle sets they will still ring.
Your welcome
Perry
Sep 28, 2007 | GE 25953 Cordless Phone
GE 25932 Cordless Phone Logo
146 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
