Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Concave screen blurred picture
Need help lining up the little cross
  • 927 Answers
Good Day, trinityfaith;;
The RCA is very different then most TV's. It could be one of four boards that's causing this. There is no common one. Please call a Factory Service Center and have give you an estimateb4 repair. Sorry, but Good Luck, big IRISH. PS You are looking at a 4 to $550.00 repair.
Posted on Sep 02, 2008
My Mits tv has sound no picture ! 3 concave lines,almost like a bowtie in middle of the screen red,green,blue. Please help ???
I would look for dry joints and poor plug socket connections around the line output section.
Mind your fingers!!!!!
Apr 17, 2011 | Televison & Video
I have a gost picture like immage on my screen all the lines are concave from left to right, the picture also blur on far away shots.
thats is the convergence module where you have two ic call
STK- , these two ic control the color line stability call convergence of color
you will need a tech specialized with samsung alignement of the convergence
therey are a little bit hard to make it right.
hope that will help
regards Alan.
Feb 28, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
My 65 mitsubishi has started to have squiggly lines through the picture when you first turn it on. the picture also goes concave then back to normal. After awhile, it stops, but is happening for longer...
Sounds like the convergence circuit is starting to fail...there are kits available for this set from tvrepairkits.com . The kit isn't all that expensive but the labor to have someone put it in may be expensive.
Jan 03, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Blurred picture
You have a convergence issue. What model do you have so I can be of further assistance to you? Please update the model, chassis number, and year of manufacture which can be found on the back of the television on the white sticker.
Feb 18, 2010 | RCA HD52W56 52" Rear Projection HDTV
Our tv is blurred... almost concaved looking and the convergences is not lining up with the crosses. What can we do to fix this?
Must know how to solders?Ur convergence ICS and all the resistors must change to fix this problem.Tries Websites Tv repair World.com,Tvrepairkits.com for the convergence kit.The Shop will cost u $300 parts and labors.
Jan 14, 2010 | Televison & Video
Tv blurred and concave w/ a half bend coming from all sides; picture off register.
The Convergence circuit has failed. it is not a simple repair and I would suggest that a Sony repair facility to do the work. I estimate the repair to be around 350.00 to 400.00.
I hope this helps,
Skyassoc
Oct 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Picture is blurred
If it's a projection tv, setting the convergence is normal and necessary sometimes. Go to the menu setup. You should find an option in there for setting the convergence. It's basically just lining up the cross-hairs (+) of all 3 colors so the picture is not so blurry. Just make sure you set all of them that you see on the screen. They all should be sitting on top of each other. Hope this helped you.
May 24, 2009 | Samsung HC-R4755W 47" HDTV
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
