Question about Kitchen Appliances - Others
Turntable Problem Whenever the microwave door is open, the turntable spins. The microwave (Panasonic 1200W) doesn't appear to be working with no digital numbers appearing on the front and no action when I push any of the buttons. Upon opening the door however, the light inside comes on and the turntable continues to run which shows that the problem is with the machine and not the electrical supply.
The problem fixed itself. I suppose it is possible that someone (not me!) dialed in a very long program such as sensor cooking which continued until the last bit of water had evaporated and the sensor detected that its work was done. That still doesn't explain how come one can't abort a process from running but I guess I can live with that until the next inexplicable problem arises. In the meantime, I can use my machine as is so don't require any assistance but thanks for offering.
Best regards
Posted on Sep 02, 2008
Panasonic NN-SN960S turntable turns on when door is open
This can be caused by a defective door latch or possibly a control board fault.
Aug 28, 2016 | Panasonic Microwave Ovens
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
My Onida Power solo 20 L 1200wqtts Microwave Oven domestic use model start moving turntable when the door is opened & stops when door closed.There is no oter problem like door & door Switches,
Possible that the switch or the lock is jammed or that the relay or main processor board is fault. Please take care that the microwave is not ON as this is dangerous.
Aug 18, 2012 | GE Microwave Ovens
I have a Panasonic Inverter Microwave , 1200w, and the turntable won't turn around. Is it safe to use without the turntable working as the motor sounds the same and the food is cooking. How do I fix this...
Hi, That is no problem, you can use is like that...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 21, 2011 | Microwave Ovens
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Turntable Problem
If it jumps or moves just a little when you open the door, that is normal. It it actually runs, then you have a problem. Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. You can visit my Web site at _ or e-mail at _ if you'd like more in information on diagnosing and repairing this problem.
Sep 18, 2006 | Goldstar MV-1502 Microwave Oven
Kitchen Appliances - Others Logo
63 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
