Well if it has been sitting, check your main things ie: you have a good or new battery, all your fuses are intact,make sure you drain all the old gas out of the bike and try to clean the carbs with some carb cleaner. It sounds like if it is not a bad battery then your gas has turned bad on you in which case it wont start until you clean it all out and put fresh gas in it.Also make sure you clean the spark plugs and check for spark.Good luck.
