Question about HP Pavilion ze4547wm Notebook
Ze4547wm the power of laptop is ok but with out display.how to repair that?
    Problem Solver:
  • 14 Answers
If the screen is very, very dim, it is the flourecent light, that is installed on the top of the screen - and may not be replaceable, without replacing the entire monitor - a computer tech can open it up (I don't recommend people that haven't been trained, as you can damage/distroy the LCD screen, and/or a paper-thin cable, rendering the computer unusable)
A workaround is to use an external monitor.
Posted on Jul 26, 2009
Don't have light on LCD screen
you can RUN the software diagnostic coming with the computer or download the s.diagnostic from your computer supplier.
However you must restar the computer HOLD the keys CTRL+f11 or f12 depend of your mark, and go to restore at factory default and try it.
If the problem persist, is time to go to the repair shop, control board defective or screen faulty.
God bless you
Jul 23, 2013 | HP Compaq 6715b Notebook
Howdo i recover from my hidden partition
Turn your computer off.
Turn your computer on, and watch for a message:
PRESS <blah> TO START SYSTEM RECOVERY
Press the <blah> key.
Jul 19, 2011 | HP Pavilion ze4547wm Notebook
Hi! I have a laptop repair Satellite A305D-s6848. I turn the laptop fan spins, no display, it can not turn off power button. Can there be a reason for the bios? Please help Hdd drive is removed,...
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 20, 2011 | Toshiba Satellite A305D-S6848 Notebook
When I push the power button nothing happens, no lights, no fan, no anything.
Hello
Thank you for using FixYa. Try these solutions
  • remove ram, and restart. any beeps?
  • Remove HDD and restart, any beeps or messages?
  • Has the unit had a powersurge?
  • Can you check to see if there voltage coming out of the power supply unit?
  • Make sure the DC jack on the laptop is firm - if broken they tend to be loose.
Hope this of some help
Thanks
Richard
Nov 17, 2009 | HP Pavilion ze4547wm Notebook
Toshiba satellite m305D screen blanks out after powering up. Power button light is out but the audio controls lights are still on.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first
Oct 16, 2009 | Toshiba Satellite M305D Notebook
I WANT LG DRIVERS MODEL LGR40
LG LGR40 laptop has no display. Cooling fan works. Processor and VGA chips heat up normally. Indicators are also ok. Power supply is ok. Anyone can suggest a chip level based repairing of it?
Jun 14, 2009 | LG E500 Express Dual Series Notebook PC
Laptop display problem
To test if the video card in the laptop is working, connect an external moniter to the video port on the laptop, then power up the monitor then the laptop.
If you get a display then the Video card is OK, you may need to press the blue Fn key plus the F4 key to switch the video output to the video connector.
If external monitor displays and image the the fault is the LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is burnt out.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 03, 2009 | HP Pavilion dv6000z Notebook
Battery not charging
take out ur laptop battery safely and again fit it to d laptop......
then see it charges or not.....
if it srill creates problem then put dis baterry in to nother laptop of same version n see how it works...
if havin same problem then it is sure dat ur battery get damaged.....
if it runs smoothly in nother laptop then i think there is problem in ur laptop...
if u hv more problem ask me for more information......
Jun 19, 2008 | HP Pavilion ze4547wm Notebook
HP Pavilion ze4547wm Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
