Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP laptop not booting up - blank screen
I think my HP laptop Pavilion dv2000 overheated. Later when I am trying to start it, it is giving 3 beep sounds and does not boot up. There is nothing on the screen. The screen is blank. when turning on..the computer starts to give 3 noisy beeps..@ the screen is black!!..while the computer is still running..
    Novelist:
    Champion:
  • 256 Answers
You should determine the exact component that is causing the issue of a black screen. For this, restart the computer first in Safe Mode. Before troubleshooting, first take a backup of all the system files. Then determine which component is causing the problem. Find the extent of the damage caused by this problem. Then measures should be adopted to solve the issue. If the issue cannot be solved by you alone, then HP customer care should be contacted.
Posted on Sep 19, 2011
    Genius:
  • 1,027 Answers
3 beeps generally means video problem,
first check this site to see if your notebook qualifies for extended warranty service
Posted on Sep 02, 2008
What might be the cause of hp pavillion dv2000 not displaying on the screen at start up and giving 3 beeps, 1 long and 2 short, sometimes it boot but doesn't get to the desktop area?
1 long beep followed by two short beeps is usually indicative of a failed/failing display adapter. On something as.... rustic as your dv2000 it can be fixed.... but probably would see better value from just replacing the unit.
Oct 23, 2010 | Computers & Internet
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
One long beep and 2 short beeps
Depending upon your BIOS manufacturer, generally this POST error code means either a video card problem or a motherboard problem. If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Jun 27, 2009 | HP Pavilion zd7020US Notebook
HP pavilion dv2000 hangs with startup screen and when i do force shut down it gives beeps until i remove the battery and the the light is keep blinking on my laptop
hello..i think their is the problem hardware on the unit..try to remove the memory and try to clean or try to replace..thanks...and Good Luck..^_^
May 13, 2009 | Dell Latitude D600 Notebook
Hp pavilion dv2000 notebook will not boot up
Now, try this: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Mar 25, 2009 | HP Pavilion dv2000t Notebook
HP PAVILION DV2000 boot problem
Your could not be booting for several reasons anything from faulty RAM to software issues. Since you cannot boot to any type of working screen you will need to use the operating disc with XP or Vista on it. Put it in the CD-ROM and reboot. Let it run for a while and it will eventually ask you to install or repair. I would try repair first as if you install then you will lose all of your data, docs, favorites, pic, etc. if you have any questions let me know.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
hi
I had the same problem faced twice in one month, and it’s a new laptop just one month old,
I have removed battery for for few minutes and fixed it back. And it's working fine now.
If it continues what should I do?
Aug 04, 2008 | HP Pavilion dv6000z Notebook
LAPTOP HP PAVILION DV2000 problem
Hello!
That beeps indicated that there is a problem in the video Graphics adapter and in the memory.
try remove and clean the memory and then fix it back, im sure that would resolve your problems. however if this not solve then your should replace the memory.
If affraid to do so, then maybe let the repairman do it for you.
fixya!
best regards, melnavz
Feb 29, 2008 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
240 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
