Question about Panasonic PV-GS300 Mini DV Digital Camcorder
Malfunctioning One-Touch Navigation & Joystick Control
I have rarely used this camcorder, and now I have taken a couple short video recordings, and I can not play them back. When I turn the joystick control to play back, it remains on record mode. Then it switches to playback for a few seconds, but the joystick does not consistently activate any of its functions. Then it switches back to tape record mode and remains there until I turn the power off and back on. Then there is another brief period in playback mode before it turns back to record mode again. The same problems occur when I switch to other operating modes. Everything clicks back to tape record mode, and the joystick acts erratically.
  • Panasonic Master
  • 19,396 Answers
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Posted on Sep 11, 2008
  • Ginko
    Ginko Sep 11, 2008
    Is it a Panasonic > PV-GS300? like in title? I can look for a download.
  • Ginko
    Ginko Sep 11, 2008
    Here is the download page for the GS3000, there is no firmware available. It is also possible that the touch panel is faulty, and that can be the cause for the camera doing funny.
    If the camera is under guaranty it will be fixed for free.
    If your warranty is expired call Panasonic and ask if they sell warranty extension
    Call Pana here By phone: 1-800-211-PANA (7262)
    Here you can also
    Find a service center
Sony hc-32 touch screen won't work
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
Retrieving old 8mm analogue video recordings at SP and LP speeds.
When you indicate that the Canon no longer produces video, what do you get? Anything at all? We may be able to "repair" the Canon to use it to retrieve the info. Please update this with a more detailed description of the symptoms for the Canon. Thanks, Dan
Jun 08, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Removing fader on Panasonic NV-GS80 video camera
TURN YOUR CAMERA INTO MOVIE RECORDING MODE. (THE RED VIDEO CAMERA ON THE DISK). tHEN PRESS THE MIDDLE OF THE JOYSTICK INWARDS. THEN MOVE THE JOYSTICK TO THE LEFT ONCE TOWARDS THE ARROW. THEN CLICK THE MIDDLE OF THE JOYSTICK AGAIN. HOPE THAT HELPS.
Jul 04, 2008 | Panasonic PV-GS500 Camcorder
Finalize
to finalize the disk for enabling discs to be  played on other devices. Connect this unit to the AC adaptor. Finalization cannot be executed using a battery. Rotate the mode dial to select the arrow. Press the MENU button, then select SETUP, FINALIZE, YES and press the joystick. Select whether or not to create a top menu, then press the joystick. When the confirmation message appears, select YES then press the joystick. hope this helps you. julie
May 19, 2008 | Panasonic VDR-D100 DVD Camcorder
DIGILIFE DDV-7300 CAMCORDER
i ve digi life ddv-7300 model purchased in singapore one year back now its working when shown to service centre they said menu script prob and spare are rarely available. so wat can i do now
May 16, 2008 | DigiLife DDV-M1 Flash Media Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Mini DvD-RW problem
You've recorded your video and you're ready to view it on a PC.
Now you need to finalise the disk before you can see it on the PC, otherwise the PC will not be able to read it.
To finalise the disk, connect your camera to the power adapter, plug the adapter into a wall socket, and switch on the wall socket, then switch on the camera.
To get to the finalise step. switch on the camera, press FUNC (on the top left side of the camera), move the joystick down to get to MENU, press SET on the joystick, move the joystick down to get to DISC OPERATIONS, then select FINALIZE, using the SET on the joystick. Finalising will now start.
Make sure you do not move the camcorder or switch off the wall adapter during finalisation - this could cause problems.
Feb 23, 2008 | Canon DC210 DVD Camcorder
To view still photos taken from canon dc-210 dvd camcorder
Sounds like you're using the "cine" setting.
Switch the camera on.
Move the "cine / photo" switch (it's just above the joystick) to the "photo" position (i.e. to the right).
Use the joystick to move between images.
Good Luck
Feb 03, 2008 | Canon DC210 DVD Camcorder
How do I playback a particular scene?
Turn the camcorder on and press the ‘Disc Navigation’ button. A list of thumbnail previews of photos and/or movie scenes will appear Select the scene using the joystick control on the DVD-Camcorder and then press the joystick or ‘Play’ button.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Open Questions:
Panasonic PV-GS300 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
