Question about Sanyo HT27546 TV
AV switch where is the AV switch usually located?
  • 77 Answers
Hiya
the av on tv's are normally done automatically on detection of a video feed via the scart sockets. if yours does not have this feature then on ur remote u shud find a button that says tv/av
rik
Posted on Feb 24, 2009
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
Red lights come on around power button
Even though your picture shows a PS3, I am going to say you are talking about the X-Box 360. How many quadrants are red?
1 quad: General hardware failure. Most likely an E74. Usually caused by a damaged hardware scaler chip.
2 quads: Overheating.Go outside and let it rest for a while.
3 quads: Red ring of death or hardware failure. Try unplugging and then replugging everything in (rare chance this will work).
4 quads: AV cable couldn't be detected. See if the AV cables are loose. See if the switch got accidentally switched to HD or SD (if you have the hd component cable). Try using another AV cable.
Sep 13, 2013 | Video Game Consoles & Games
How I switch the channel to av on the dv1320p prima color tv? its a tv/dvd combo.
You will need your hand remote to switch from Tv to AV, usually labeled on one button.
May 13, 2012 | Televison & Video
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    LG RI32CZ10RX, switch to AV with no remote?
    usually the code for a phillips tv will operate lg tv's
    Mar 17, 2010 | Televison & Video
    When trying to switch from AV1 to AV2 with the
    The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
    Oct 24, 2009 | LG Televison & Video
    Cable from Camera to TV
    Usually AV connectors are located under cover.
    If you provide me exact model of JVC camcorder so I can help you to locate AV connector.
    Mar 12, 2009 | JVC Video Cameras
    My ps3 has no picture or sound...
    if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
    Jan 22, 2009 | Sony Playstation 3 (PS3) Console
    Reciever turns off
    Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
    Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
    Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
    Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
    Nov 24, 2008 | Onkyo TX-SR606 Receiver
    Unable to locat and select the AV channel on new LCD HD TV
    Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
    Cheers and have a Happy Holiday Season!
    Dec 21, 2007 | Televison & Video
    Sanyo HT27546 TV Logo
    160 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
