Machine constantly empties
I have 'inherited' a used Mistral washing machine with no instructions! Help please. It seems that whichever way I set it it simply fills with water whilst emptying at the same time. I guess it has something to do with 'overflow rinse' but even when I set it without any light in this window - it still seems to constantly empty. It does agitate at the same time but if I switch it all off while the drum is full of water it empties .....
Anybody know the solution or where I could get an instruction manual that might help. Any assistance would be very much appreicated. Sue
  • susiehalford Sep 02, 2008
    Thanks for the advice. The washer will spin and I have discovered that if I hold the draining pipe up in the air the washer functions 'normally' and only empties at the appropriate time. It would seem that the previous occupant somehow managed to use it with the drain hose positioned far too low. We are going to put a taller plastic drainpipe in, thus elevating the hose, and see if that works. Many thanks for the suggestions though .....
  • 639 Answers
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Posted on Sep 02, 2008
  • Neil
    Neil Sep 03, 2008
    Most washers will only pump water a limited distance from he washer unless you get a 2 speed and it's pump is strong enough!
    For example I have customers who need their washer to pump the water from their washer up 7 feet from their basement that is under ground and the drain is high on the wall at ground level!
    I sell them the Speed Queen 2 speed washer!
    the best warranty in the industry and they start from only $549 each!!! And they use only 36 gallons of water, wash 8 loads a week for 25 years!
    And wash in only 35 minutes and dry in half the time form all the others! which means half the electric or gas bill!!!
    A REAL NO BRAINIER!
    But people buy what they see on TV and in the ad's rather than the machine in the laundromat's around the world!
    peace,
    ngfam1 Please give me the best rating at fixya.com, before you exit!
Can we use washing machine after we found a dead rat
Hi
Thanks for using FixYa. Yes you can use it however, before using it run your washing machine with only two cups of vinegar in it and make sure it is empty & set on its hottest temperature setting so that all the smell is gone. Please revert back for more help.
Rylee
Dec 24, 2011 | Samsung Washing Machines
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
How to use thomson washing machine tx 708
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Jan 15, 2010 | Thomson Washing Machines
Need instruction manual
To download the instruction manual, please click on the link:
Gevalia CM-500 Manual
Sep 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Old Washer won't spin or agitate
change the spinner switch
Apr 01, 2008 | Washing Machines
MISTRAL MTLW7..2 too many probs!
e4 error on my mistral MTLW7 washing machine want spin
Mar 27, 2008 | Washing Machines
I have a mistral MTLW7 washer and it is having trouble with the spin cycle, it comes up with an error code on the display screen, and will not spin again, as all of the clothes are over one side. The...
Im no expert but i have found the hight of the water outlet is kinda critical to correct function on mine.
The manual states outlet to be no less than 700mm and no more than 1200mm and i have mine now at 900 mm and its all working fine.
Originanly was hooked in under sink and exerienced similar problems
Hope this helps ya out
Dingo~
Instruction manual
Here is a link:
http://www.mistral.com.au/products/manual/BMH110.pdf
Dec 09, 2007 | Kitchen Appliances - Others
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
