Master
- Posted on Aug 03, 2011
Re: Sorry for my terrible english ! - I load a drumgroove...
- So if I understand you right, and I think I do. You are putting the looping on so you can record your own tract but for some reason the amount of time you think you have recorded is not being reflected in listening to the playback correct?
- When you push play then the beat will begin to play. It will continue to play until you stop it. Now while the beat is playing you want to hit "record" to record anything you want to have recorded. If you hit the record button again then this will pause what you are recording BUT you will continue to hear the loop. This allows you to choose different parts of the loop to lay a chop down on. So in other words if you press play (this allows the selected loop to being) then you press record to record everything. If you press record again while the loop is playing this will stop ALL recording but you will still hear the selected loop playing. You have to press record again to continue recording.
- Also remember that if you have somehow reached 24 minutes of recording then you have to remove it to make room for more recording. You do this by hitting the "undu" button.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
I'll try to explain step by step :
- I select a drumgroove
- I push the record button in order to record my guitar line
- after 5 seconds (a few days ago, this were 60 seconds), the system doesn't allow me to record any longer
- automatically, after these 5 seconds and without me pushing any buttom, the system starts to play my recording and I can't record a new line because the recording button refuses to react
