Question about Canon PowerShot G5 Digital Camera
Canon g5 lcd display problem
I am also having a problem with my G5 display. Although the display appears completely blank, If i look very closely, at the correct angle, I can make out the menu and function screen images. I don't believe that following the posted solution of "re-attaching" the display wire would work because if it was detached, I don't think I'd see anything. It appears that the backlight, if there is one, is out. Any ideas?
I had the same problem but did not have a soldering iron small enough and did feel adept at soldering microcircuitry in any case.
I unscrewed the four side screws, rotating the screen slightly to get at the ones closest to the body of the camera. Carefully removing the back I turned the camera on and noticed that by pressing on the two contacts located at the bottom left where all the circuitry is, the screen came back on full brilliance. I cut a small piece of plastic off of an old credit card approximately 1/2" X 3/4" of an inch. I then folded it in half (biting it tight and then opening it to create a bit of spring). I then carefully placed this double thick plastic over the contacts in the lower left and sandwiched the cover back on. Pressing it tight and put the screws back and voila!... works like a charm. The double thickness of the plastic and little extra pressure from folding the plastic over and opening it a bit was just enough pressure to solve the contact problem.
I expect some technicians will think this is kind of a *cheat* but from my experience with soldering - especially tiny stuff, I just did not feel comfortable with that option. Anyway hope it helps some other novices, it is a quick fix.
Artist3d, Still lovin my Canon G5
Posted on Apr 01, 2009
I actually had exactly the same problem. It was caused by the display wire being loose. It's got two connections, one of them was loose. So I guess the ghosty images at the proper angles was being caused by the one connector that was hooked up. I just soldered the loose one on and it worked fine!
Posted on Oct 09, 2008
LCD for Canon Powershot G5
did you look at the ifixit.com website? Not sure they already did the G5, but you never know.
Oct 27, 2013 | Cameras
Canon G5 Powershot LCD screen is black and will not show images in any setting.
Are you sure the battery is ok? Did you press the button display (bottom right nest to the display) several times? Next, how long did you not use this camera? If it was for long, something inside could be corroded. Did you recently drop the camera? Something more serious could be wrong. I'm not sure you can make any picture, because you don't need the screen to make a picture. You then could look is a proper picture is on the memory card. If the rest of the camera is working ok the viewing must work also. Check is the off button is moving correct. (And not blocked) Resetting could be an option, but you need the display to answer the question. This is in the user manual.
Oct 23, 2013 | Canon PowerShot G5 Digital Camera
Canon a2200 screen
The LCD screen inverter maybe faulty. Take your camera to the Canon repairer to have the camera fixed.
Apr 06, 2013 | Canon PowerShot G5 Digital Camera
Ik Krijg verschillende kleuren lijnen op m'n lcd van canon g5
Eerst moet je het "model" & "generatie"van uw G5 iMac moet je wetenHoe je je iMac te identificeren http://docs.info.apple.com/article.html?artnum=301724-enVerkrijgen van informatie over uw computer http://docs.info.apple.com/article.html?path=Mac/10.4/en/mh355.html
U kunt deze informatie weergegeven op de bodem van elk bericht door te gaan naar 'Mijn instellingen' die zich bevindt in de kolom aan de rechterkant onder uw naam, en het invullen van de gevraagde informatie.
Controleren om te zien of uw model iMac in aanmerking komt voor een van de iMac G5 reparatieprogramma programma voor video en voeding
Als uw computer niet in aanmerking komt, hopelijk heb je AppleCare.
Mar 21, 2011 | Canon PowerShot G5 Digital Camera
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
Power failure
Check the fuses on the printed board circuits.
They are labeled with a P, H or K in the middle of them.
Check them for zero ohms to test them with a meter,.
Regards,
May 24, 2009 | Canon PowerShot G5 Digital Camera
Canon digital G5 LCD monitor problem
Very simple fix. Open the covering on the lcd screen and also remove covering that is between the camera and screen. There is a wire that goes from the lcd screen to the camera. It came out from all the twisting of screen when opening and closing. Carefully put that back in. Google keywords like "lcd g5 fix" etc. for more detailed description.
Jul 20, 2008 | Canon PowerShot G5 Digital Camera
Canon PowerShot G5 Digital Camera Logo
1,287 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
