Question about Car Audio & Video
Got a 2005 honda civil battery died now radio wanted a code got the U and L code from the radio using the 1 - 6 preset buttons but need the 5 digit code to restart the radio
  • 1,586 Answers
You have to get that from the dealer if it's not in your owner's manual packet. Bring title and registration to the dealer and they can look it up based on the VIN of the car. They also will likely charge you - anywhere up to an hour's labor.
Posted on Sep 02, 2008
My 2005 Honda pilot had battery disconnected then read code and now says error? I tried putting in radio code still error?
Sounds like you have the wrong code, maybe the radio was replaced? Hold preset buttons 1 and 6 then turn on the radio. It will display the radio serial #, 4 digits then 4 more. Dealer can get you the code. Or you can register at the owners site online and get the code yourself.
Jan 25, 2015 | 2005 Honda Pilot
I have a 1993 Honda Accord EX and the battery died and locked up the radio, I have the code to unlock, but need to know how to insert it since my radio display is not working.. Please Help...
disconnect battery and let it set for an hour , reconnect battery, it should power up, if not check your fuses, turn radio on code should come up, using your six preset radio buttons( # 1-6) type in the code and it should reset
Feb 28, 2010 | 1993 Honda Accord
Replaced the car battery and now my radio needs a code...I can't find my code....
I had the same problem. Here is the fix that will be free. Find out were the car was purchased from,( Honda Dealer, I hope ). Talk to service and give them the VIN. They will have the code on their computer. The cde will be 5 didgets in length. When you speak to them sound realy stuck! If you don't have the owners manual; here is how to enter the code: There will be a button button that is either marked code or it will be the am/fm button. Press this button untill you here a beep. Then using the presets buttons 1-5
enter in the code. The radio should then turn to some station. Turn the radio power off and back on enter you radio fav. stations.
Dec 01, 2009 | 2005 Honda CR-V
Need the radio code for my 1999 honda accord. the radio will not play since my battery died. Bought the car 2nd hand and can't find the 5 number code anywhere
*** Please click the "Was this helpful? Yes" (thumbs up)! ***
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
Sep 07, 2009 | 1999 Honda Accord
My battery died on my 2002 Honda Accord. On one
What you have is the SERIAL NUMBER. Your almost there!!! The hard part is over! Go to the bottom below for the website option or phone number option you need to get the unlock code!!!
---Internet option:
-OR-
* REMOVING ERROR E3
Aug 28, 2009 | 2002 Honda Accord
2003 Honda sportscar- battery died-restarted it now radio says "err-1"
On Hondas when power is not supplied to the radio it goes into a safe mode, this is to help prevent it from being stolen. You will need a code to input into your radio. If you call or visit your local dealership they can look up this code using your VIN, it is typically a 6 digit numerical code, you just use the preset buttons to enter it. If you bought the vehicle new you should have this number in some of your paperwork/manuals. Good day!
Jun 14, 2009 | 2007 Honda Fit Sport Hatchback
Honda radio codes I have just bought a used Honda CR-V in the Caribbean, and need to change a few things, removed battery and cd player died. I cannot find the sticker anywhere with the code and do not...
Don't post your s/n & vin online!!
---Internet option:
-OR-
* REMOVING ERROR E3
May 30, 2009 | 2004 Honda CR-V
I have the unlock code for my 94 honda accord radio but cant figure out how to enter it
First clear all codes. remove the neg. battery cable for 10 sec. then turn the radio on it will display CODE. Enter the 5 digit numbers using the preset buttons numbered 1 to 6.
Apr 19, 2009 | 1994 Honda Accord
Need to input my radio code on 2005 Honda Civic
ok your radio displays ERR , OK 3 options let it sit for an hour turned on , to reture to CODE display , or pull the radio fuse out for a minute and put it back in , returning to the CODE display , or disconnect the battery for a minute , returning to the CODE display . you got the ERR display because the code was wrong or not entered correctly , make your choice of getting the radio back to the CODE display by 1 of those 3 choices , while the radio displays CODE , use the preset buttons , if the first number of your code is 4 , then press the #1 preset button 4 time , when the first number has been input , put the 2nd number in by pressing the #2 prest button , if 2nd number of code is 8 , press the # 2 preset button 8 times till the # 8 is displayed , and so on . you see where this is giong ? when you have entered all the numbers correctly you will have you radio back . when you say you have the radio code , good luck ! were rooting for ya .
J5
Jan 19, 2009 | 2005 Honda Civic
Honda radio codes
turn the radio off push preset buttons 1 &6 while holding these buttons turn on the radio the serial# will come up call the dealer with this # they should give you the radio code if you have a problem write back i can get it for you if you have error on the radio then disconnect the battery cable neg for aprx. 30 seconds reconnect the enter the code using your preset buttons
Aug 01, 2008 | 2007 Honda CR-V
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
