Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Dryer Wet Inside
I have one of those new Maytag front loading dryers with matching washer on stands. I was gone for a couple days, tried to use the dryer tonight and it's all wet inside and won't turn on. Before I left I had dried a load of socks, everything came out dry, I closed the door and left.
There is power to the machine because the light comes on when I open the door but it won't turn on; I'm assuming because of the water. The door was closed, no water anywhere in the laundry room, washer works fine, the only opening to the dryer is the vent but it travels a long way through the garage to the outside. Any ideas????
  • 639 Answers
Ngfam1 at your service
The water perhaps came in through the outside vent! check the vent cover outside that it is still on and in place! And not stuck open if it is a swinging door type!
If its off or open it may have been wind swept rain coming in the vent pipe !
If still no start!
Try unplugging the dryer for 10 minutes and then to plug it in and attempt to restart it!
Let me know if this helps!
If you need service here is ,
A&E factory service which is nation wide and open for appointments 24/7
They due most warranty work too!
Bless You,
Please leave me a good rating here at before you sign off!
Posted on Sep 02, 2008
    Problem Solver:
  • 12 Answers
If your dryer is spinning but no heat, your "Air fluff" button on the Temperature Selector switch is press.
If it is not press, the contact inside the switch is open.You have to change the switch.
Burns clothes!
cheak this out once
Feb 08, 2008 | Equator EZ 1500 Front Load Washer / Dryer
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
On my front-loading stacked Frigidaire dryer, the clothes are coming out of the washing machine nearly dripping wet. What is the best way to deal with this?
Final spin does not appear to be working. Clothes are soaking wet after the buzzer has gone off. Any ideas would be helpful. Thanks.
Dec 21, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
I know fuse is gone on Maytag MAH7550AGW but how do I access the motor control board? Which screws do I need to remove etc?
8 screws inside lip of dryer door including door hinge screws the hold front panel will come off the control board will be bottom right front.
Sep 28, 2009 | Maytag Neptune MAH7500A Front Load Washer
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
