Question about Ricoh Aficio 1035 Copier
How to connect ricoh 1035
I inherited a Ricoh 1035 multifunction printer,copier scanner. The nachine did not come with a manual. Is it possible to connect to a personal computer? if so please provide step by step instructions
On the control panel of the printer, there is a row of buttons on the left hand side listing the options available on your copier, ie Copier, Document Server, Fax, Printer. If "Printer" is not listed, you do not have that option on your copier.
Posted on Sep 21, 2008
  • 158 Answers
First, check on the left side of the machine to see if it has either a USB or RJ-45 receptical to plug your computer into. If not, the machine lacks the hardware needed to print from your computer. A Ricoh technician must install it at extra cost. If you DO have either of these recepticals, go, to download the manual and drivers you need.
Posted on Sep 02, 2008
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Sc690 for ricoh 1035
That is not an easy task...
From what the manual says you have a BICU defective. Looks like a bad connection or somethings.
I advise you to call your provider. I think there is nothing you can do
Mar 05, 2011 | Ricoh Aficio 1035 Copier
I am looking for scanner driver of Ricoh Aficio 1035 3 in 1 printer
hello mate. go to and under the downloads you will get the scanner driver.
Dec 19, 2010 | Ricoh Aficio 1035 Copier
I do not have scanner driver
go to ricoh website and put your model 1035 and put scanner driver for 1035 or search on google
Ricoh aficio 1035 scanner problem,can scan but pc "hang " why?
1).Restart your computer. 2).reload printer driver on your computer.
Oct 31, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Connecting ricoh 1035 to pc
connect your copier to a switch or router.
Goto user tools/counter. Select interface settings. Enter the IP address of the copier, enter the gateway address to the router. Press file transfer. Turn the deliver server on. It will take a few seconds but it should populate the IP address to the computer that desktop binder is installed to and insert the users assigned to the scanner program.
Sep 02, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
305 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
