Question about Texas Instruments TI-83 Plus Calculator
Screen Gibberish My Ti-83+ is about 6 years old but not until a couple of days ago did this problem occur. I turned it on to find gibberish all over the screen. I pressed clear without any luck. I changed the batteries, cleared the ram, pulled all the batteries including the lcd and let it sit overnight, and updated the OS via another TI-83+. Nothing has worked so far. Any thoughts?
  • Anonymous Sep 04, 2008
    Ditto.  I have had this problem for months and I really don't want to buy a new calculator.
  • VT Hokie Sep 14, 2008
    Yeah, I ended up contacting TI and they sent me to their trouble shooting page which contained everything I had already done, clear the ram, reinstall the OS etc. They also mentioned that since my calculator was so old, they could not do anything for me. So I ended up just buying a new one. Thanks for all the input.
    Scholar:
  • 149 Answers
You dropped your calculator one too many times, or the solder joints broke some other way. Get a soldering iron, liquid flux, and solder and resolder all of the chips on the mainboard.
Posted on Apr 27, 2011
  • Chris M. Apr 27, 2011
    Another common cause is the white flex cable connecting the LCD to the main board. Peel that off of the board (it isn't soldered), tin all of the pads and solder wires onto them in place of the flex cable. Try this first, since the cable is folded, and over time the connection breaks at the fold.
This is by no means an official opinion, but I'm almost 100% certain that this happens when memory on the calculator fries. When the processing chip tries to read information stored in memory telling it what to print on the screen, the memory returns incorrect values and as a result areas of the screen which are supposed to be empty have pixels filled in and vice-versa (depening on how much of the memory has failed).
This exact same problem happened on my laptop computer (with video memory) a couple of weeks ago and it turned out to be both a problem with the video memory failing, as well as the video interface on the mainboard.
Once again, I haven't called TI yet to confirm this, but I'm nearly 100% certain that this problem is caused by bad memory sectors.
TI MIGHT replace a calculator if it has this issue, or maybe repair it for less than the cost of buying a new one. I'm not sure yet; this problem just happened to me and tech support isn't open till monday.
Posted on Sep 06, 2008
Wow, I'm in the exact same situation. I've had my trusty TI for 6 years and now all of a sudden this gibberish is on the screen. You're right, there is absolutely nothing you can do to fix it. Guess we'll have to bite the bullet and buy a new one.
Posted on Sep 05, 2008
My mom's hp officejet T45 printer now prints gibberish. It started after my sister installed a new ink cartridge for her. Because her documents were printing nothing but a solid black line then, my...
Gibberish sounds to me that ether one of two things is going on.
1. the printer was never allighned when the new cartridges where put in.
2. Depending on the gibberish its printing it could be a communication error with the driver on the computer.
Do not pitch the printer but get help for it like you are doing now! But I would have taken a chat from us to see what the gibberish is!
Dec 18, 2009 | Cameras
Gibberish + won't finish loading Windows
remove the new memory first. if that does not help you may have some a virus, indicated by safe mode workng fine. One other thing i found would do that is a damaged Hard drive, not to likely here because safe mode works.
Apr 28, 2009 | Dell Dimension E521 PC Desktop
Epsonstylus C62 prints gibberish when turned on.
How can I fix my HP J5750 printer that prints gibberish with a compatable HP PC.
Dec 25, 2008 | Office Equipment & Supplies
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TI-83 Plus Silver Edition problem
Use a paperclip (tiny hole on back of caculator) and reset.
JC
Sep 16, 2008 | Texas Instruments Office Equipment &...
My screen on my T40 shows lots of gibberish colored squares
If you have access to an external monitor, connect it to the laptop. If everything works properly, then the screen or inverter has gone out. If you get the same garbled screen, then the video card has gone out.
Jul 28, 2008 | IBM ThinkPad T40 2373 Notebook
Gibberish on the Front Screen
Try unplugging the unit for 30 seconds then plug it back in. The power outage may have been erratic and the MW did not reset properly.
Jun 16, 2008 | GE Advantium 120 Convection/Microwave Oven
No Power
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 04, 2007 | Texas Instruments TI-83 Plus Silver...
My ti-83 plus has OS problem
That happened to me a few years ago - my friend tried to give me his operating system, and my calculator was all locked up like that for a while. There's some kind of reset code - pressing some buttons while putting a battery in - but it's been a while, so I don't remember which buttons.
Apr 15, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
742 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
