Question about Panasonic PT-47WX49 47" Rear Projection Television
47 projection the tv will not turn on and the power light blinks 5 times pauses and repeats whats the problem?
  • Cindy Rourke Oct 03, 2008
    I have the same problem. I live in Jacksonville, FL. Where can I go to get this fixed? And do you know if this is expensive....??
I have a PT47WX52Cf Panasonic well watching it the other nite it just shut off can not turn on with remote have to unplug and then it comes on for a second and back out red light is flashing on front
Posted on May 18, 2009
Which IC?
Posted on Sep 15, 2008
    Sergeant:
  • 284 Answers
im sorry to say but you need to have a IC replaced on the main board to fix this
Posted on Sep 11, 2008
Turn tv on,tv shut off then power light blinks 3 times,pause and continue to blink 3 times
Check the site www.TvRepairKits.com - your convergence may have shorted out causing the tv to power off.
Apr 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
My TV does not turn on the green light steadily blinks. Can you please let me know what I can do without calling service
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
Dec 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Wont turn on, turn power on and tv turns off and you hear click.
DO THE SELF CHECK WHEN POWER LIGHT GOES OFF.
On front of set press and hold both the menu and input buttons for at least 5 seconds and release both, power light will blink a two digit error code like 2 blinks, 2 blinks, and pause and repeat several times.
Let me know error code and I will tell you what it means.
SD TECH
Dec 07, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
When i turn my tv the screen is bkack and the red light is on
POWER LIGHT SHOULD BLINK A ERROR CODE: 3 BLINKS REPEATED OVER AND OVER OR 5 BLINKS.
UNPLUG SET AND PLUG IT BACK AND TURN IT ON AND COUNT FOR BLINKS.
LET ME KNOW WHAT YOU FIND, I KNOW THESE SETS WELL.
sd tech
Aug 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My tv wont tun on, the on button blinks red
PT-47wx53? This means the set is in shutdown---unplug the set and plug it back in and turn it on----when the power light blinks try to count the sequence---
for example___3 blinks, a pause and 3 blinks---it should repeat this several times---count carefully and let me know the number of blinks
3 blinks is the most common and the easiest to diagnose for repair.
let me know what you find, I am here to help people.
If this has helped you rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Beeps when turned on then power light blinks 5 times
sound like the b+ line is not getting the voltage call a tv repair tech.
Feb 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
