Question about Epson PhotoPC 3000Z Digital Camera
External flash for the 3000Z
What is the best external flash for the 3000Z? I'm currently about to check out the Vivitar 283, but that flash was made for film cameras and I'm not sure if it is going to work satisfactorily with the 3000Z. All of the settings on the flash are related to the type of "film" in the basic camera. Any suggestions or recommendations?
    Master:
  • 542 Answers
Actually, for an automatic exposure, self-contained (non-TTL) flash, manual mode is really the only mode that makes sense. And by that I mean full manual, not just the "Manual" mode selectable from the settings section on the mode dial. The "manual",selection on the settings menu, at least on the 850z, really should be called "full control" rather than manual in the film camera sense. I'm asumming that the 3000z is not all that different (except for the perplexingly absent shutter priorty mode). From "Manual" set in the setup screen, when you switch back to shooting, you can then select auto exposure aperture (shutter too on the 850z) priority, or full manual (although full manual without the flash is difficult to use - metering help on the 850z is essentially nonexistent - just the little EV! warning with no indication of whether you are over or under or by how much). My 283 fires in any of the "manual" modes, although it really does only make sense to use it in full manual because the flash control is built into the flash, not TTL on the camera. Here's how it works (again, set the camera to full manual mode) - if you set your camera iso to 100 (the default) then you can pick any shutter speed - yes, the camera seems to synch at ALL speeds - I usually shoot at 1/250. Then pick an aperature appropriate for the depth of field you want, and using the guide on the side of the flash, pick the sensor (the little twisty thing on the front of the flash) setting color appropriate for that aperature. At ISO 100 the settings are 2.8, 4, 8 and 11. I find that the 2.8 setting gives me about 1/3 stop overexposure - wish I could set the camear to f3.2 or so - but that I get great results with the 2nd power setting and f4.
Posted on Sep 13, 2005
    Master:
  • 542 Answers
After checking out the Vivitar 283, I found that it (and any external flash) will only work in the "manual mode" with the 3000Z. I called Epson and they confirmed that their firmware is written for the flash to work only in the manual mode (will not function in the Program or Auto mode). Is this a normal thing with all digital cameras? Doesn't make sense to me. I would think that an external flash should work in any mode selected. And another question. When setting up a flash unit, how do you convert the values for the different types of film (which the flash units seem to be based on) to realistic settings when using a digital camera which doesn't use film? Most of my photos taken in manual mode were highly overexposed as I didn't know which settings to use on the Vivitar flash. Just learning though, and I suppose I will figure it out as I experiment more.
    Master:
  • 542 Answers
I use the Sunpak 383 Super on my 850Z, and it works fine. For under $100, I couldn't beat it. I found the Metz that Epson recommends to be overpriced and over-featured for a point-n-shoot digicam.
    Master:
  • 542 Answers
I can't say which flash is best but the Metz is excellent and worth the money if you plan to use external flash a lot. I bought a Vivitar 2800 at ritz for $50. It tilts and comes with filters and difusers. Used it on the 850 and now the 3000 with good results in manual mode at 1/60 and set the arpeture to the scale on the back of the flash. Has adequate power for my needs.
    Master:
  • 542 Answers
Bought the Metz 32 Z-2 that was recommended by Epson. I did a great deal of searching/researching on the web, and eventually came to the conclusion (my personal conclusion...YMMV..as well as others) that it was worth the price. I've also had two (non-digitial) pros hold the metz name in very high regard. I like it so far although I haven't used it much for nice portraiture. I did use it at the beach one night in the *dark* from 10 meters (couldn't see *anything* on the LCD when snapping the picture) and a few turned out really nice. Some were not in complete focus, but hey, it was dark. I will say it is much larger than I expected. When mounted on the 850 it felt nice. But with the 3000 being a little smaller, it is rather large. With a teleconverter lens and the flash mounted together, the whole ensemble feels rather nice. I'd recommend finding one in person first. It does have about all the features one could want tho...
SOURCE:
Where can I purchase a new or used battery holder for a Vivitar 283 flash attachment? Mine was left in too long and the batteries destroyed the contacts.
Best place for finding Vivitar 283 anything is on e-Bay, I use a gang of them doing my location photography and have several holders preloaded with batteries so when the cycle time starts to get more then I can bare I just switch out the holders.
All my stuff came off e-Bay.
Feb 21, 2011 | Vivitar 283 Flash
The sync input on my vivitar 283 flash is not functioning. Is there anything I can do?
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Dec 29, 2009 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Is it compatible to use with a Nikon D-50?
No, the Vivitar 283 does not have TTL (Through The Lens metering capability) and the voltage in the flash may be much higher than that in the camera. Some of the old 283 flashes had a very high operating current that, when the flash is left one and removed from the camera can damage the camera operating circuts. Find a Nikon SB 400, 600, 800 or 900 speedlite, or a Promaster 7200 or 7500 for a great less expensive flash for this camera.
Nov 20, 2009 | Vivitar 283 Flash
Battery holder for Vivitar 283 is broken. Can I get a replacement
I think there are some listed on Ebay-check it out.
Dec 27, 2008 | Vivitar 283 Flash
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
3000Z and Speedotron Flash power pack
You also may have a faulty hot shoe adapter or pc cord. Check them with an ohm meter, or with an old 35 mm camera. Or just short out the hot shoe contacts with a piece of metal and see if the strobes flash.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
External Flash for 3000Z
I have tried a couple of external flashes on the 3000Z. It is my understanding from reading various Internet posts (and I am sure someone will correct me if I am wrong) that, other than triggering the flash to go off, there is no communication between the external flash in the hot shoe of the 3000Z and the 3000Z itself. Settings need to be made manually in the manual mode to set the f-stop and the aperture to get good exposures. The Metz flashes are expensive. Most have opted to use less expensive flashes such as the Vivitar 283/383, or a Sunpak, or even a "Wal-mart" flash. I chose an inexpensive bounce flash with a secondary "fill-in" flash to get rid of the shadows sometimes seen with indoor bounce flash pics. I purchased the Phoenix 82ZBDA Multi-dedicated twin flash from Porter's Photo Catalogue for $37.95. This flash works fine, but is not that powerful (GN 79 ). If you need a more powerful flash, you might consider the Vivitar 383.
Can the internal flash be disabled when using externally attached flashes?
t is my understanding that you must use manual exposure (shutter and aperture) with an external flash. This shouldn't be a problem (set the camera to the settings on the guide chart that comes with your flash, and let the flash worry about the strength/flash duration necessary - provided it is an "auto" flash with a sensor)... I'm going to use a Vivitar 273 with my Epson 3000z... There are a few other threads on this forum regarding External Flash use.
Epson PhotoPC 3000Z Digital Camera Logo
97 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
