Question about RCA D52130 52" Rear Projection Television
Rca d52130 herd pop tv went dead
I was watching tv and i heard a pop sound and tv shut off.
pressing the power on does nothing.
checked main fuse inside near power plug its fine
its a 2002 model
any ideas?
thanks
tom
  • xr7honnes Nov 29, 2008
    I turned on my D52130 and it just went off after 3 or 4 minutes. Now It will not power up with the remote or the front panel power switch.
    Took off back cover but can not find a circuit breaker but can see a fuse in left rear corner of chasis on the circuit board next to a transformer but can not reach it to remove to check it.
    If fuse is not blown what woulde cause this???
    What is protection mode I have read about on the web and how does it work???
    Sergeant:
    Champion:
  • 227 Answers
Dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
caypianan@yahoo.com
Posted on Oct 22, 2008
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hitachi clu-4591av stopped working - popping sound
The power supply regulator section should be troubleshooted. The "Pop" sound you heard might be of a bursted electrolytic capacitor in the AC mains rectifier section inside the TV. All the related commponets, rectifier diodes, protection zener diodes etc:- should be checked before switch ON the TV further.
May 15, 2012 | Televison & Video
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture but have sound
That click might have originated in 2 places: either it was the main relay disconnecting or it was the sound of a capacitor popping. Both are very severe problems - they signal that the power source of your tv has just failed.
Fixing it is a job for someone with electronics experience, if you're not one then call a repairman.
Jul 26, 2010 | RCA P42WHD33 42 in. Plasma HDTV
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
My RCA projection tv died
Ur BD power inverter board is dead.One of ur Capacitor or rmore it dead.U know how to solders?Buy the parts and replace it.Or buy the whole board and replace it.
Sep 02, 2009 | RCA P46924 46" Rear Projection Television
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
No Power
Your set is going into high voltage shut down. Might have been the high voltage transformer that has gone bad.
Mar 09, 2007 | Hitachi 60UX58B 60" Rear Projection...
RCA D52130 52" Rear Projection Television Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
