Question about Yahoo Diamond Vision DVDC803-04 DVD Player
DVDV809-04 I have bought some new DVDs but everytime I try to play them the message says wrong disc. I have tried all the codes to change the region but they don't work.
  • kjh150562 Apr 18, 2009
    i tried this with 809-3 ; did not work. menu comes up in language selection default. I entered 1 3 8 9 pressed enter and it just interpreted the enter as a response to the language menu option.
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
Posted on Jan 02, 2009
My portable DVD player keeps displaying a message of "wrong region" instead of playing the discs
That means that the region code of the DVDs that you are trying to play in the unit do not match the region code that the player is set to. Often people buy DVDs for real cheap only to find that they are pirated copies from overseas and have other region codes that do not match their machine. If that is not the case, you need to check to see what region code your machine has. Most can be changed, but there is a limit to how many times you can change the region code on most devices so be sure to know what you want before you start messing around.
Jan 31, 2016 | Televison & Video
Is there a way to change the region code on a Sony HCD-S300 Please?
Unfortunately, you have a DVD player that is "Region Specific" and cannot be changed. Your system has a region code printed on the back of the unit and will only play DVDs that are labeled with identical region codes. DVDs labeled "ALL" will also play in this unit. If you try to play any other DVD, the message " Playing this disc is prohibited by area limits." will appear on the TV screen. Depending on the DVD, no region code indication may be labeled even though playing is prohibited by area limits.
Mar 26, 2012 | Televison & Video
I recently bought some dvds from the UK. JVC XV-S65 dvd player will not play them. It reads 'region error' everytime I try to play the discs. HELP!
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
Feb 02, 2011 | Televison & Video
I'm having disc error messages or/and I cannot play dvds region 4
Below is a process to unlock the region's in that DVD player. There were a few methods try this one and post back letting me know how it goes.
1. Remove any disc in the tray.
2. Using the remote, turn the power off.
3. Turn the power on.
3. Open the empty tray.
4. Close the empty tray and wait until the player recognizes there is no disc in the tray.
5. Press "Menu, 1, 9".
6. A large rectangular area will appear in the bottom half of the screen; in the middle of the rectangle will be a single number that identifies the region to which the player is set.
7. Pressing the number keys on the remote will have no effect. Instead, use the up or down arrows above and below the "enter" button to change the region number. ("0" presumably is "region free".)
8. Once you have selected the region code (i.e., the number that now appears in the middle of the rectangle) press "enter".
9. Press the "opne/Close" button and the unit will save the selected code.
Hope this works let me know .Thank you for choosing Fixya! Feel free to leave a positive rating if this solution helps.
Mar 21, 2009 | Cyberhome CH-DVD 300 DVD Player
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Jan 22, 2007 | Yamaha DVR-S120 DVD Player
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Yahoo Diamond Vision DVDC803-04 DVD Player Logo
555 people viewed this question
Top Yahoo Televison & Video Experts
Craig Butler
Craig Butler
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
