Question about Dell Axim X5 Pocket PC
Bad Pixel
One of our new Axim's (the 400mhz) came with a dead pixel - right in the middle of the top portion of the screen. Sadly, it is right in the center of the blue "Start" bar and very noticable. Is this a valid issue for screen replacement?
    Master:
  • 852 Answers
I think the minimum "bad pixel" qualification for manufacturers (for LDC monitors) do not apply here. Mainly because 1 bad pixel in a PDA screen is much more noticeable than a 15inch monitor. In any case, even if Dell doesn't get reimbursed for the bad display, you should have no problems getting a replacement from Dell.
Posted on Sep 13, 2005
    Master:
  • 852 Answers
If I can remember correctly... There is a percentage of cold pixels that are required before a manufacturer will resupply you with a new LCD display... I have no idea if this counts for PDA's or not, but I do know that it applies to Monitors.
    Master:
  • 852 Answers
Of course it is. A defective product is a defective product. The specs say 240 X 320 which is 76800 pixels but they onle sent you 76799 that work!! lol
How can you fix dead pixel?
FIXING DEAD PIXELS These WEB site gives instruction on removing dead pixels, but there is no guarantee it will work except replacing the LCD screen.
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
http://komku.blogspot.com.au/2008/03/dead-pixel-on-your-laptop-screen-how-to.html
Nov 27, 2012 | Computers & Internet
White spot on screen
Sounds like you are describing stuck/dead pixel.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel
Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Jan 12, 2008 | Samsung HL-P6163W 61" TV
Tip
How to fix a dead or stuck pixel on an LCD screen
A dead or stuck pixel on an LCD screen or TFT can be incredibly annoying. You'll be staring at it for days on end, wondering for how long you'll be without your screen or maybe your entire laptop if you decided to turn it in for repair or replacement. All that grieve over something as unimportant, yet highly irritating as a malfunctioning pixel.<br /> Before you run the item back to the store though, you should try to see whether you can fix it yourself! This, if done carefully, will not hamper your warranty and might save you a lot of time and worries. So let's see what you can do yourself.<br /> Let me say that any new LCD or TFT monitor should be tested for pixel errors. This can be done simply by running it through a palette of basic colors and black and white in full screen mode. The software, which we'll get to in a second, can do that.<br /> First let me explain what you may be seeing. Is it just a stuck pixel or is it in fact dead? A stuck pixel will appear in any of the colors that its three subpixels (red, green and blue) can form, depending on their functionality and brightness. In a dead pixel all subpixels are permanently off, which will make the pixel appear black. This may result from a broken transistor, in rare cases however even a black pixel may just be stuck. So if you're seeing a colored or white pixel, your chances are pretty good and if it's black, there is still hope.<br /> Let's turn to the software now. If you're not on Windows, scroll down for some online tools!<br /> <b><a href="http://udpix.free.fr/">UDPixel</a> (Windows)</b> I recommend UDPixel to quickly identify and fix pixels using a single tool. The program requires .NET Framework 2.<br /> <p><img src="fixpixel02.png" /> With the dead pixel locator on the left you can easily detect any screen irregularity that may have escaped your vision until now. Should you have identified a suspicious pixel, switch to the undead pixel option, create sufficient amounts of flash windows (one per stuck pixel) and hit start. You can drag the tiny flashing windows to where you found the pixel in question. Let it run for a while and eventually change the flash interval.<br /> <b><a href="http://flexcode.org/lcd.html">LCD</a> (online)</b> This is one tool that lets you find and eventually fix stuck pixels. It packs many options into a singly tiny window, but once you have an overview it's straightforward and easy to use.<br /> <p><img src="fixpixel06.png" /> To test the screen click the small 'pick a color' box. The colors you should test are red, green and blue. Additionally you should test white and black. Follow the instructions in the box to gain the best results.<br /> <b><a href="http://tft.vanity.dk/">Online Monitor Test</a> (Online)</b> This is a very thorough test not only meant to identify bad pixels, but also powerful enough to test the quality of your monitor. You can choose between three different modes to test your monitor. This tool either requires flash (online version) or it can be installed in the executable mode.<br /> <p><img src="fixpixel03.png" /> What you will need to just test for stuck pixels is the HTML window. Toggle full screen by hitting F11. What you will see is displayed below.<br /> <p><img src="fixpixel04.png" /> Move the mouse to the top of the test window and a menu will appear. There is an info window that you can turn off with a button in the top right of the menu. Then click on the homogenity test point and move through the three colors as well as black and white. Fingers crossed you won't discover anything out of the ordinary. In the unfortunate case that you do, you may find the following online tool helpful.<br /> <b><a href="http://www.jscreenfix.com/basic.php">JScreenFix</a> (Online)</b> Alternatively, and if you're not using Windows XP, you can use the online tool JScreenFix which launches a Java applet to fix stuck pixel.<br /> <p><img src="fixpixel05.png" /> The tool launches a small applet in a separate browser window and you can drag the window to the respective spot or run it in full screen.<br /> Hands On (Offline) Should none of these tools resolve your pixel issue, there is one last chance. You can combine any of the tools and the magic power of your own hands. There is a very good description of all available techniques on <a href="http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor">wikiHow</a>. Another great step by step guide can be found on <a href="http://www.instructables.com/id/Fix-a-stuck-pixel-on-an-LCD-monitor/">instructables</a>.<br /> But let's go through one technique real quick:<br /> <ol> <li>Turn off your monitor.</li> <li>Get yourself a damp cloth, so that you won't scratch the screen.</li> <li>Apply pressure to the area where the stuck pixel is. Try not to put pressure anywhere else, as this may trigger the creation of more stuck pixels.</li> <li>While applying pressure, turn on your computer and screen.</li> <li>Remove pressure and the stuck pixel should be gone.</li></ol> This works because in a stuck pixel liquid in a subpixel has not spread equally. In combination with the backlight of your screen, this liquid is used to allow different amounts of light to pass through, which creates the different colors.<br /> Should all of these approaches fail to fix your pixel warrior, at least you'll now know it's not simple to fix and the LCD may indeed need to be replaced. But please do let us know if these tips helped you to fix your pixels. In any case, good luck!
on Jan 04, 2011 | Sony KDF-E55A20 55 in. LCD Television
Dead pixel line?
Hi, The problem with pocket PC is that you can't do something to test and find if the problem comes from the display or the graphic processor. If the device is not too old, you can try to repair it. In case that the device is more than 10 years, buy a new one. Sorry.
May 30, 2017 | Dell Axim X30 Pocket PC
Dead pixel how to resolved
Dead pixels are shame from manufacturers. They all tolerate them (you need to have more than eight for returning). Only few manufacturers talk about free of dead-pixels. One possible solution is pressing the pixel (not so hard press) and than shutdown the screen. Sometimes it will recover frozen pixel, but if you press to much, it can make another one. If you have enough for return, it will not be so bad if you have guarantee. If you are lucky to not have dead pixel transistor, this can help. But if transistor is dead, you will not success with this technique.
Aug 25, 2011 | Computers & Internet
Horizontal lines across the screen
actually it is called a dead pixel. You can't fix it unless you will replace your LCD. Sorry for the bad news but it is for a fact. Hope I have answered your question
Jan 06, 2010 | HP Compaq Presario C500t Notebook
Black spots on screen in the top corner and bottem of screen
how big are the black spots? are they pixel size? i have one black spot too but its called a "dead pixel" when ya buy laptops these days, sometimes...they will have a dead pixel gaurentee for like 25 dollars, but i didnt choose that so now im stuck with one annoying dead pixel on my 5 thousand dollar laptop but im fine with it i guess. when my screen gets bad, im rich enough to just replace the whole screen anyway. dead pixels cant be fixed i dont think just replaced by the whole screen.
Dec 25, 2009 | Toshiba Computers & Internet
Dead pixel
Dead pixels cannot be fixed, each pixel is controlled by a transistor that is part of the LCD screen. If it is bad, the only option is to replace the LCD screen.
Mar 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dell Axim problem
Most likely a bad connection along the sides of the screen causing a line of "dead" pixels. I have a similar problem with an old GPS reciever (several lines). You could attempt to repair but that would be risky unless you purchased a new working screen and replaed the entire screen (can find on ebay at times)
Apr 28, 2008 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
50 people viewed this question
Clive
Clive
Alun Cox
