Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg washing machine error code is ie - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • 1 more comment
  • onehotgoat Dec 08, 2008
    where do I get the part to repair???
  • bbeatty Dec 13, 2008
    OE error code
  • STEVEN NEUNHOFFER Oct 20, 2013
    OK..."BRENDA" you and the person who calls themselves by women's names need to go to YouTube and watch how to take apart a LG Front Load Washer. There are about 10 videoa. Now the problem. You have either no Spin which is cuasing the washer to Not drain. Right! Answer: Yes Mr. Forrest Gump! Now purchase a Drain Pump (watch out there are 2) not the circulating pump. This is a bolt on procedure, the hard part is taking the ENTIRE washer apart (almost) and then install the drain pump. Button it up (re-Assemble) and then wash. Fixed!
  • 1,543 Answers
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Posted on Sep 02, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
SOURCE: LG washing machine Model WD 1433RD
I had the same problem. I thought it was the motor it turned out I had a nickle wedged in the filter (bottom left behind panel) the nickle blocked the water pump makeing the pump overload.
Posted on Jan 10, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
MNTECH
  • 1543 Answers
SOURCE: WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Posted on Nov 27, 2009
Model LG 2131SH is giving an IE code. Have replaced the Inlet Valve and still receiving the IE Error
Check water pressure. Check inlet filters--the ones inline at the back of the washer. Try a cold water only wash or try a hot/hot wash a see if you still get the error.
Apr 28, 2017 | LG Washing Machines
Lg washing machine ie fault
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters
Dec 03, 2016 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
What does error code IE mean?
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code.
1) partially or fully closed water supply lines
2) improperly attached supply hoses
3) clogged supply hose filters (on machine and in the hoses).
Nov 20, 2014 | Sears Kenmore Elite 4.5 cu. ft....
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Washing Machines Logo
1,611 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
