I'M TRYING TO SEARCH IN THE WEB BUT I CAN'T GET
PLEASE HELP ME TO SOLVE HOW TO SET JUMPER OF P4V845 SERIES MOTHERBOARD.
HERE MY HARDWARE DESCRIPTION;
CPU-INTEL PENTIUM 4 1.70GHz(100X17.0), DDR PC2100 128MB, V3800M/PURE 32MB VIDEO CARD AGP, HDD-IDE MAXTOR 40GB, 52X TEAC CDROM DRIVE, INTERNAL MODEM 56KBPS CONEXANT.
ERROR;
CMOS CHECKSUM ERROR - DEFAULTS LOADED
WARNING! CPU HAS BEEN CHANGED. OR CPU RATIO CHANGED FAIL,
PLEASE RE-ENTER CPU SETTINGS IN THE CMOS SETUP AND REMEMBER TO SAVE BEFORE QUIT!
  • meandi Nov 16, 2008
    I too have the same problem with my Foxconn 755/760A01 motherboard but mine started with the date change from BST to GMT I get the CMOS checksum error - defaults loaded which always loads to Wed Jan 01 2003, I change and save it in CMOS but at next bootup it goes back to 2003, should I change the CMOS battery?
    Many thanks
    Tony.
  • 928 Answers
Normally Checksum errors mean that the Battery on the board may not be holding a charge any longer. Best suggestion that I can give is to replace that battery. You can buy it in any electronics store. Just make sure to buy one with the EXACT same size. If that still does not work you may ahve to update your BIOS you can message me about that.
Posted on Sep 02, 2008
Audio driver for P4V845 SERIES
if your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
hope this helps you
Mar 15, 2012 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
My desktop motherboard p4v845 series and operating system is winxp and i can't download a specific sound driver please help me
You should be able to obtain the driver on Intel's website. It would be for the 845 chipset.
Oct 09, 2010 | Computers & Internet
Usb not allow usb 2.0
There is no jumper settings about it. There is somethign a problem with your USB ports in your motherboard and it could be a hardware defect. To solve this, buy an expansion USB card and plug it to the available slots of your motherboard. Hope this can help you. Please don't forget to rate me. Thanks..
Oct 26, 2009 | Computers & Internet
P4V845 motherboard...
i need audio driver for p4v845sm
Nov 19, 2008 | VIA P4MA Motherboard
My gateway m series is asking for my hdd pasword when i turned it on ive never set one up so have no idea what to do at its stuck on it
I am assuming this is a BIOS password.
Inside your case on the motherboard there should be a password reset jumper. You may have to search for it. If you have documentation on your system, it may help. You can also get help from Gateway support for your specific model and motherboard.
You normally have to move the jumper from pins 1 & 2, to pins 2 & 3 and reboot. You should get a message that the password has been cleared. Shut down, move the jumper back to its original position and reboot.
Nov 07, 2008 | Computers & Internet
Motherboard driver
That is probably an ECS motherboard but I can't be absolutely certain as I didn't see your exact specified model # on their site. I bet there is another # somewhere on the motherboard that will allow you to determine exact model #. To that end I recommend downloading and installing SciSoft Sandra ( newest version ) from here
This program should help you determine exact manufacturer and model #, and if it is an ECS motherboard as I suspect that it may be, then visit this site to find the motherboard on manufacturer website and download the drivers there.
In the long run you will be happy you used drivers from a manufacturers website vice the many so-called driver sites on the web. A lot less hassle.
Aug 26, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
VIA P4V845 CHIPSET MOBO FOR iNTEL p4 CPU PROBLEMS
Hi, USB issues - Probably the BIOS. Have you checked the BIOS version? VIA P4V845? Also I get the impression that P4V845 have 2 versions, SX & SM, that it is an Intel chipset based mb and not VIA and that it was probably by one of the OEM vendors for Pc Partner. In any case, should you want to flash/update your BIOS, this might be of help to you > http://www.wimsbios.com/phpBB2/topic8315-15.html Good luck and kind regards.
Aug 29, 2007 | VIA P4MA Motherboard
Computers & Internet Logo
572 people viewed this question
David Payne
David Payne
