Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
No Thumbnail video folder view
All video file folders affected by no Thumbnail view, only get folder icon. Tried the obvious: Tools/Folder Options/Restore Defaults w/ no help. Files view fine on my Dell laptop with identical software.
Windows XP Home, SP3, current updates
    Problem Solver:
I was hoping to hear a quick registry fix but just bit the bullet and did a deep System Restore and all the updates that went with it. Works fine now but will never know what caused it. Still open to any and all info.
Lauripoika
Posted on Sep 02, 2008
How can i view hidden files in windows xp?
Kindly follow the following steps to view your hidden files in your PC...
1. Double click & Open the 'Windows Explorer / My Computer'
2. From the file menu bar select 'Tools'
3. Select 'Folder Options'
4. Select the 'View' Tab on the Option Window
5. In that tab you will find 'Hidden Files & Folders' with a folder icon
6. Select the 'Show Hidden Files and Folders' by selecting the radio button.
7. Then select 'Apply'
Now you will be able to view the hidden files & folders in your system. I have enclosed the screen shots for your better reference.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
Tip
How to convert thumbnail into ICONS in windows 8 interface
First time I installed windows 8 i faced that problem that in place of icon it was showing only thumbnail. So here goes the solution to convert thumbnail into icons in windows 8 interface-
Open up the folder with the pictures and click on the View tab
Next click on Options to the far right
Then Click on Change folder and search options
This opens up an options menu
Navigate to the view tab
uncheck the box that says Always show icons, never thumbnails
And Check the box that says Display file icon on thumbnails.
This should solve the problem. It worked for me.
on Apr 13, 2015 | Microsoft Windows 8.1 - Windows
Tip
Removing Thumbs.db Files
When viewing a folder with the Thumbnail view, WindowsXP creates a thumbs.db file.
This is a cache of the current pictures in that directory.
If you want to turn this feature off and save a little disk space
  1. Start the Windows Explorer
  2. Go to Tools / Folder Options / View
  3. In the first section under Files and Folders, check Do not cache thumbnails
  4. Now you can search for the thumbs.db file on your computer and remove them. No more should be created.
on Oct 03, 2010 | Computers & Internet
Icon background in Windows XP 2
It looks like a custom view for a music folder. Try right-clicking on the folder in Windows Explorer, then select the 3rd tab, "Customize", and change your folder type.
Jan 27, 2010 | Microsoft Windows XP Professional SP2
Any way to make thumbnail view a default?
Your best bet is to use the built-in File Browser. It has 2 panes: 1 is a directory tree and the other is a thumbnail view of folder contents. I know Photoshop has this and would expect that Publisher has the same. So instead of going to File>Open, use the File Browser which is usually located near the top right-hand side of the toolbar within the application. Double-click a thumbnail to open the file.
There might be a special command within the application or a Windows registry setting that would enable a default thumbnail view in the Open dialog box, but I don't know of one off hand.
Dec 27, 2008 | Adobe Photoshop CS2 for PC
Tip
on Sep 20, 2010 | Computers & Internet
Tip
How to view hidden files in Windows
Files can be hidden in Windows for a variety of reasons. Certain system files can be hidden so that a careless user doesn't accidentally delete or modify them. Personal files might be hidden by their creator so that other users can't view them. And malware or spyware programs might install themselves and hide the files to make them harder to find.
But whatever the reason a file is hidden, you can view hidden files if you want to in Windows. To set Windows to show hidden files, open a folder or go into Windows Explorer and under the Tools menu, click Folder Options. Go to the View tab, and under the heading "Hidden files and folders," click the radio button next to "Show hidden files and folders." Then click Apply or OK.
Now, when you view a folder that has a hidden file or subfolder in it, that file or folder will be visible. When you see a hidden file in a Windows folder, it will be listed right along with the rest of the files in that folder, but its icon or thumbnail will appear faded and pixellated. You can open it and access it just like any other file, but it's technically "hidden."
To change a file's attributes so it's not hidden anymore, right click on the file and select Properties. In the General tab, at the bottom, uncheck the box next to "Hidden" and click Apply. Now, when you view the folder where that file resides, it will look the same as the other files. (If you want to make the file hidden again, just go back into its properties and re-check the "Hidden" box and click Apply.)
on Jun 03, 2010 | Computers & Internet
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
How can i install icon pack in my windows xp sp2
Change Folder Icon:
  1. Open Windows Explorer
  2. Right klick your folder of choice
  3. Choose Customize tab in the new window
  4. Choose a new folder image for Windows Explorer’s “thumbnail” and/or “icon” view
  5. Navigate to your new icon/image of choice and choose it
Regards
Balisonu79
Feb 15, 2008 | Microsoft Windows XP Professional With...
How do i delete pics from my sandisc sansa e260.
what you need to do is this. i cant help you if you have a mac but i can help you if you have a pc. for pcs, you need to plug in your player.once its connected, double click "my computer".in it, the player should have registered and their should be an icon that says "sandisk sansa e260" ( or something like that, i couldnt exsactly tell you considering my player is completely busted at the moment.)then you should see a bunch of files.the files will include album art,songs,and folders for videos or pictures.in the pictures folder you can access your pictures,and right click on the files you wish to delte, and simply just...hit delete.
Oct 08, 2006 | SanDisk Sansa e260 MP3 Player
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
49 people viewed this question
Alun Cox
