Question about Samsung SGH-D900 Cellular Phone
D900 motherboard or screen?
I have a d900 which comes on with a blank screen the backlight works but nothing appears on the screen, i can make and recieve calls again nothing appears on the screen, i had take the phone to a shop to fix and they have made it worse this cost me £40... and now it doesnt even vibrate1 help!
  • Anonymous Jan 21, 2009
    i cant even make calls on minee!
    Brigadier General:
  • 7,752 Answers
Well you should take it back and have them fix it the correct way
Posted on Sep 13, 2008
My acer aspire 4530 have a problem in screen. as i swithct it on, nothing appear in the screen as in all blank. but all lights in my keyboard are on,, only the screen... Is it a problem in hardware? if...
This is because of backlight problem. Check you didnt accidently turn off the backlight. Usually pressing the Fn button and F6 at the same time is the backlight on/off togle on acers.
Please try holding the Fn button and pressing the left/right arrow keys raises/lowers the backlight brightness.
If this helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely Thiyaga
Aug 28, 2011 | Acer Computers & Internet
I have samsung mobile D900i. The problem is. my keypad shows the light but no backlight on the screen. The screen is blank. Plz help !!!!
you have defective flex cable a ribbon type connector thats connect your screen to the main board of your phone replacing it will fixed your phone.
Jul 04, 2011 | Samsung SGH-D900 Cellular Phone
Hi I have a Acer aspire 9410 (9414wlsmi) 17 screen. The problem is that i have no backlight at all, i've bought a new screen + new inverter/backlight driver + new cable but it did'nt help i have...
The inverter/backlight combination isn't the whole picture. The inverter powers the backlight, but the inverter is controlled by a signal commonly called "Brite-On", which comes from the motherboard. If the "Bright -On" signal from the motherboard is missing,then the inverter (and thus the backlight) won't work. The problem you are having is on the motherboard. here's a link to a datasheet of such a device:
http://pdf1.alldatasheet.com/datasheet-pdf/view/245132/FAIRCHILD/FAN7317.html
May 15, 2011 | Acer Aspire 3690 (LX.AFL0J.044) PC...
My n95 8gb phone screen has gone blank. the backlight is working but there is nothing on the screen
lines appear and the cam flickers on and off any bodie help new ribbon fitted new nokia updated
Nov 02, 2010 | Nokia N95 Cellular Phone
My laptop comes on but screen is blank. Nothing shows up pitch black
it is most likely either your backlight tubes, or the backlight tube circuit board needs replacing. backlight tubes can be obtained off of ebay from a gentleman in oklahoma city oklahoma.
Jun 23, 2010 | Everex StepNote NC1500 Notebook
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be...
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq V3424au that has a blank screen on startup with all lights
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Compaq Computers & Internet
Acer travelmate 5100 has a blank screen
The first problem; most likely is the board. try replacing the ram and dusting the inside out very thouroughly..especially near the cpu. you can also try running it with the adapter with no battery and see what happens.
2nd guy: your backlight in the screen is dead and generally its not cheap to fix. if you can find a used screena dn someone to put it in for cheap it might be ok but for now you can use the external monitor.
Apr 01, 2009 | Acer (ACERMOTHERBOARD)
Samsung sgh d900
replace the lcd on the phone.
Jun 02, 2008 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
604 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
