Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Hello. I have a Triton GE dishwasher. It has worked great for the past 3 years we have owned it (was a used dishwasher we bought on Craigslist). Anyways, I just built a working counter top that surrounds it, put it into it's place and it does not drain all of the sudden. I pulled the drain line that connects to the new garbage disposal (which the new garbage disposal had been relieved ((aka drilled out) of it's factory stop so the dishwasher can drain freely) and checked for anything blocking it's flow. I also reset the dishwasher with the drain line off to see if there was any pressure, and there was not except for the last 2 seconds before it would completely shut off, about a cup of water shot out....and that was it. So as far as I know there is something wrong with the dishwasher.....any suggestions. Thanks you Mario
    Novelist:
  • 166 Answers
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Posted on Sep 07, 2008
Just fixed mine! Used a shop vac to **** all the water out of the bottom of the washer. Then ran it on a rinse cycle and it filled back up. Disconnected the drain line and taped it snug to the shop vac. Sucked it out with shop vac. Refilled washer using rinse...Then reversed vac to blow. Then sucked it out again. Then started cycle when the pump came on it wasnt pumping...hit shop vac on **** it sucked and bingo pump started working. Hooked drain line back up and ran two cycles. Its working fine. Saved hundreds!!! Tools required: screwdriver to remove line. Shop vac and good ole duct tape to make a good seal on the line and the vac line. Bingo it drains!
Posted on Nov 08, 2008
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
My GE Triton dishwasher won't drain, I need URGENT help !!!!! :(
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 21, 2011 | GE Dishwashers
GE TRITON SEEMS TO STOP BEFORE CYCLE IS COMPLETE AND NOT DRAINING
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
599 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
