Question about HP PSC 1610 All-In-One InkJet Printer
Right Cartridge The info window says to remove and check right cartridge. Does tht mean I need a new cartridge? I keep taking it out and putting it in but it says the same message.
  • 114 Answers
Generally this means the cartridge is defective.
Lou
Posted on Sep 02, 2008
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
Installing new cartridge?? The cartridge is hidden at one side, so I can't get at it. And I can't move it because the scrren comes up' cartridge is empty!!!
switch on you printer on then open the front cover then the cartridge will be aligned in the center remove the cartridge and take the new cartridge from the box keep the cartridge up right remove the sticker from the cartridge and insert them to the cartridge holder
Feb 25, 2011 | Computers & Internet
I have just installed a new colored cartridge in my Lexmark printer (Number 29). My computer keeps telling me that the cartridge needs to be replaced and I cannot print at all. My laptop is Windows...
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Aug 10, 2010 | Lexmark Office Equipment & Supplies
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
The cartridge on the right is the black ink cartridge. The one on the left is the color.
Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
Keeps saying remove and check cartridge , its a virtually new cartridge
Sometimes the problem is with the other cartridge, and there's a wire spring on the right where the right cartridge goes, that comes loose and tears a hole in the ribbon cable, which means you need a new carriage assembly, more money than a new printer.
Sep 02, 2009 | HP PSC 2175 All-In-One InkJet Printer
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
New ink cartridge for epson cx6600
If the computer shop said the new chips may not be recognized by the old printers then I would suggest you get an old cartridge which the printer recognizes and a chip resetter for Epson cartridges. Remove the new cartridge w/ the new chips and replace it with the older chip. You will probably need some double sided adhesive. When you pull out the chip you will notice 2 circular areas that hold the chip to the cartridge. One is actually like a small horseshoe so that you can slip it right back in. But the other one has a round flat end on protruding through the chip before you remove the chip. When you remove it, the plastic caves into the hole making it possible for you to remove the chip easily but impossible to put back. So to put in the older chip you need to snip out that piece of plastic so you have space to put in the adhesive. You can even use a small stretch of masking tape by rolling up about half an inch then putting it behind the chip. This way all you need to do it just change the chip everytime you run out of ink. It is a hassle but since you have bought large a supply of cartridges, don't waste it.
Apr 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP 1350 not working
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Aug 16, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1610 All-In-One InkJet Printer Logo
184 people viewed this question
Seeker5211
Seeker5211
