Question about Proscan Televison & Video
Closed captions Is there a closed caption function for the Proscan 47lb45h television? If so, can you tell me how to turn it on and off?
  • 30 Answers
In all situations I've seen:
A) It's an option on your cable/satellite box.
B) It's a broadcast signal and it's in the TV menu.
Posted on Sep 02, 2008
How to turn off closed caption?
Go to your TV menu and seek for "Closed Caption" menu. Select mode off (no mode 1, 2 etc). If you describe your TV model it will be more exact the help we can give you.
May 07, 2014 | Proscan PS36700 36" TV
No closed caption
When a television tells you that no captioning is available it is telling you that the broadcaster is not supplying closed captions. You are doing everything right, but the show you are watching is not captioned.
Nov 17, 2012 | Maxent MX5020 50 in. Plasma Television
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
I wish to use closed captioning but I can't find the function on my Panasonic TH-42PWD6 monitor. Does it have a closed captioning function, and if so how can I turn it on and off? Thanks.
Researching this monitor, it appears to be a professional monitor with plug-in modules for different inputs. It does not appear to support closed captioning natively.
However, some Set Top Boxes (STBs) do closed captioning themselves. For example, most newer DirecTV STBs have captioning capabilities on the box rather than using the montior's closed captioning feature. Perhaps your source material can open caption for you.
May 06, 2011 | Televison & Video
ProScan Model 40LC45S There is a black box in the middle of the screen only on one station. How do we make this go away?
This is a text box and is part of the closed captioning features your television has. You would have to turn closed caption off completely on your television. There should be a cc button on your television remote or in the television menu there should be a closed caption sub category you can go to and select off.
Jan 07, 2011 | Proscan Televison & Video
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
Feb 08, 2009 | Proscan 32LA30Q Television
Black Box overlaid on image
Go into the menu and find "closed captions. Once there, turn off the "text" function. If you don't use closed captions, turn it all off. This will make your box go away. Let me know if I can be of further assistance
Jan 07, 2009 | Proscan PS27108 TV
Televison & Video Logo
150 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
