I don't know what you mean by recognizing ..but i suppose it does not start the recovery process..and this may have a few causes..
The first thing to check is if the disk is having an operation system on it or it is just the drivers and factory programs recovery ..In this case you need a boot-able disk with the operation system on it ..and use the recovery disk after installing the system first .
Another thing may be just a boot issue ..If your computer does not have the boot from cd enabled ..this may be an issue ..so my advice is to press f2 on stat and go to BIOS settings ..and look for boot sequence and select the cd /dvd drive as first boot device ..and hard disk the second..and save the changes by pressing F10 ..and restart ..This will make the disk to boot like it should if it has the correct information on it ..It will ask to press any key for confirmation of the disk boot ...and go with the installing .
there is a 3rd possibility in which you have to load the ahci driver for the system first ..cause the recovery disk loads the files but do not see a boot disk ..cause the hard disk by default is set to work on the ahci function of the sata bus..and if you do not load a 3rd party driver for the ahci ..it does not see the hdd..In this case load the driver from a floppy or from a usb ..and go on with the process or just go to bios ..and look for the ahci feature in the advanced settings or in teh devices..and disable it and let it run sata as ide or ide compatible ..save settings with F10 and restart ..It will never ask for driver again and will load the recovery if the disk is functional .
i hope this will help ..cause I covered almost all possibilities but a faulty disk in which case you just have to get a boot-able disk with the operation system you use and reinstall it clean ..and run the drivers after doing it ..and install all programs needed manually .
Please rate my answer if it helps ..and thank you for using our site !..
have a nice day !
