Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Color ink leaking
My color ink cartridge seems to be leaking blue ink inside the printer and the screen on the printer says to take out the color cartridge. Is there a problem with the printer or just the ink? Please advise :)
  • stuvickars Oct 25, 2008
    puddles of ink under both cartridges and soome turqoise sprayed around
  • Anonymous Dec 23, 2008
    Exact same thing, turquoise sprayed by the color cartridge and pools under both black and color. When I pay 30 bucks for an ink cartridge i expect the ink to be on the page not the bottom of the printer.
  • 234 Answers
Are you using a refilled ink catridge,
If yes then please use a geniune HP Ink catridge.
Even if you are not using a refilled or Non HP Cartridge try these steps:
Take out both the ink cartridges from the All-In-One and unplug the power cable from the printer aswell as the wall outlet.
With a lint free cloth and little drinking water soke the lint free cloth it only needs to be moistioned clean the ink cartidges and the internal area on the All-In-One with the cloth and wipe off the ink from the printer and make sure it is all clean and dry (if you need more cloth do it untill it is clean).
Then insert cartridges back to the All-In-One make sure you do not touch the metal contacts, close the access door and plug the power cable diretly to a wall outlet with out a surg protector and then plug it back to the All-In-One and check.
Good Luck
Posted on Sep 03, 2008
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. Recap the used ink cartridge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unwrapping it. You do not need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do not shake the cartridges after opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shown above. Doing so may prevent normal operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into place.
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Nov 17, 2014 | Epson Expression Premium XP-610...
How can I fix my ink problem?
It is possible the ink carriage and print head are very dirty and needs servicing.
Aug 25, 2014 | Brother LC51BK Print cartridge, Inkjet...
I had the blue ink leak inside my C6180 printer and now it won't print in blue. How do I fix this? Thanks
What you really saw was a really light blue or "cyan" color. Right?
Replace the Cyan Ink cartridge.
Your Cyan ink cartridge leaked it's ink out, and now it is dead.... Bad cartridge, if it was "brand new" (or nearly brand new), ***** to the retailer that sold it to you, they should replace it for free. Have invoice handy, ask to speak to the "manager" or "boss" (a "supervisor" is still a "peon", and can't make decisions like that).
If they give you the run-around, ask to talk to the OWNER! If they shut u down (and/or **** u off), and the store is local (within driving range) bring the printer into the store (dripping ink and all) and raise holy hell. You'll be surprised how fast they "throw" ink cartridges (even new printers) at you to get rid of you 8^). Nothing smells of death more, to a sales person or manager, than an irate customer on the sales floor!
BTW, You'll want to clean up any excess "blue"/cyan ink that was leaked inside your printer, or you'll get ink blotches on you printouts.
Let me know if this help ya! Cheers...
Jun 17, 2011 | HP Photosmart C6180 All-In-One InkJet...
I just replaced my blue cartridge a couple weeks ago. Seemed like it wasn't time for that. But now the printer says the cartridge is empty again. I refuse to replace the blue cartridge every couple of...
The printer could be reading the cartidge wrong, if i were you i would just keep using the blue one until you see it stop printing blue on your papers. If it stops quickly, then you probably need to check your printer settings to see if you have it set to print the color black using a mix of your colored ink cartridges.
Thumbs up if this helps! Thanks
Mar 03, 2011 | Epson Stylus CX9400 Photo Printer
Color cartridge leaked inside on cartridge docks and need to know how to clean it off
Hello!
Well, first of all, open the lid of your printer and remove the cartridges. Use a lot of tissues and i also recommend a pair of gloves, as it can be messy. All you need to do is wipe all the ink that has leaked in your printer. By cleaning the cartridge docks you will also clean the residues of old ink. If your color cartridge is still leaking, just put it on a tissue (the print head should be on the tissue) so it can extract the excess ink.
Hope that helps!
Mar 05, 2010 | Lexmark JetPrinter Z22 Color InkJet
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
Blue ink - printing problem
Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge!
Good luck.
Sep 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
IP4200 Printing wrong color
Try
www.fixyourownprinter.com
In the field type your printer and model
Take no notice of adverts.
Also try Canon support
Jun 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Losing Ink
Depending on how many times you have refilled the wells of the cartride the sensor inside may be going bad as the manufature of the cartridge only intended it for a one time use. My recommendation would be to buy a off brand compatible and refill those.
Mar 07, 2008 | Canon BJC 8200 Photo InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
177 people viewed this question
Ben Johnson
