Need to totally blnak out
How to re image my sansa e260. There is some type of virus in it that make it malfunction. Need to wipe it all out and start from scratch.
    Brigadier General:
  • 3,614 Answers
You have to reformat it by connecting it to your pc.
Posted on Sep 02, 2008
I think that my sansa e260 have a virus, which could be the solution?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa 260 4GB
Will Windows read it as a flash drive?
If so, find a file recovery program like undelete or something, use it to restore your files, then turn on the sansa, then select format( if it is a view) and it will delete all your songs
Oct 25, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Donwload the Sansa Recovery Tool form Sandisk's website
Jun 26, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Hola a todos, les dire que tengo un Sansa e260 y el problema que tiene es que cuando la conecto a la pc la reconoce como USB Device y no la instala y la pantalla se queda en negro, ya tengo su firmware y su rom, solo quiero ver como resetearla o algo.
porfa, ayudame si pueden
fqueija@ict.uho.edul.cu.
Jan 05, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 won't accept pictures
Are you using the Sansa Media Converter to convert / transfer the photos?
Thats the only way to get photos / videos on the Sansa Products.
The Sansa Media Converter is here if you need it;
http://www.sandiskthailand.com/images/SansaMediaConverter.zip
Best of Luck.
Oct 25, 2007 | SanDisk Sansa e260 MP3 Player
Pluuuuuuuuuuuuuuuuuuuuuuuuuz
get the sansa sandisk media converter( i comes w/ the mp3
Sep 04, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
 Grubhead
Grubhead
